Question about RCA TruFlat 27F520T 27" TV
Rca 32in TV Product serial#f483ceok5 RCA 32in
Rca 32in TV Product serial#f483ceok5 RCA 32in 084604204138 TV turns on but shuts self off after 15-20 min Sleep timer and shut off modes are disabled Off
  • 134 Answers
Try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Posted on Feb 10, 2011
6ya staff
SOURCE:
Rca 32in. tv randomly shuts off
A good idea would be to open set if able and look for bad or broken solder connections in or around the high voltage transformer.
Dec 20, 2012 | RCA Televison & Video
DIRECT TV REMOTE WON"T WORK WITH MY RCA 32in LCD
if you want to use a single remote, try buying a learning remote
Aug 13, 2009 | iLO 3200 32 in. LCD Television
My rca lyra keeps turning on and off and when i hit the play button it shuts off and turns it self back on It turns on and starts to play but will shut off or if you try to go to the next song it shuts...
How old is the Lyra, sounds like the battery isn't charging or is in need of replacement...
You could have a look here > http://www.rcaaudiovideo.com/product.aspx?product=410
May 28, 2009 | RCA Pearl TH1102 MP3 Player
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
32in. rca lcd tv GOES BLACK
this is the conversion IC chip , it needs to be replaced
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
Rca tv will not power on
Check the horizontal output transistor. This may be shorted.
Mar 12, 2008 | RCA D52W19 52" Rear Projection Television
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
32 in RCA turns on and off
your problem is in system control section or there might be a problem of loose connection in system control.
Sep 20, 2007 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
254 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
