Friends ... i discovered a way that you can power on the dell studio 1535 easily ...
first of all you know the power button .. it's now working ( or stuck )
in the other side of the labtop, there's a wifi button, when the labtop is already shutten down, you can press it and it will give a light then shuts down the light in the button, that means that it gives power, now to complete the process you should know the touch button in the left side that means Dell MediaDirect ( touch control button of the dell studio ) ..
ok, Now, do exactly what i'm telling you :)
1- when the computer is shutten down, plz press the wifi detector button one press
2- it will give a light then shuts then gives light again for a longer time.
3- when giving the first light for a short time, do not wait, press the media touch button quickly, continuesly and separetly.
it it doesn't work ... try it for many times tell you know when exactly to press the media touch button
then you'll see that the labtop starts as if it was in sleep :)
You restart the loptop pls!!!!!!
SOURCE: dell studio 1737 mousepad not working
You can try the steps below and this definately should fix the issue.
Download and install the latest touchpad driver:
Uninstall the touchpad driver:
1. Click the Start button, point to Settings, and then click Control Panel.
2. When the Control Panel window appears, double-click the Add or Remove Programs icon.
3. Locate the software for your keyboard or mouse in the list below.
• Microsoft IntelliPoint software
• Logitech software
• DellTouch software
• Synaptics software
• Alps software
• Set Point software
4. Click to highlight the device name and then click the Remove button.
5. Follow the prompts to uninstall the input device driver/software.
Download and Install the Latest Touchpad Driver Available:
Please follow the link below to install the latest touchpad driver.
http://tinyurl.com/5k9tth
1. Locate “Input device drivers” and click on (+) sign next to it.
2. Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3. Click Save.
4. When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5. When the download is complete, go to desktop and locate the same file.
6. Right click on it and run as administrator.
7. Click on allow and follow the simple instructions to update the touchpad driver.
Please do not forget to rate the solution.
Regards,
Musheer.
SOURCE: AC PLUG FOR STUDIO DELL 1737
you can find one on ebay for $20
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: "click" feature will not work on Scrollpad of Dell Studio 1737
install the touch pad driver and the configure the seetings in control pannel
Testimonial: "Thanks so much for your response. I'm not a computer whiz (as anyone can tell) and this was a tremendous help. Thanks again."
