Question about Jandy AQUALINK RS TELELINK KIT
I have a Jandy Aqualink. The spa jets keep turning on.
Posted by martinlgreen on
5 Related Answers
Anonymous
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
Anonymous
  • 125 Answers
SOURCE: Have a Jandy aqualink clorinator.
link to the Trouble Shooting Guide
Posted on Mar 04, 2009
Anonymous
  • 61 Answers
SOURCE: Spa only gets to about 90 deg
For a quick fix you could swap out the air and water temp sensors. They should be exactly the same.
Posted on Apr 12, 2009
poolyoda
  • 128 Answers
SOURCE: We have the Jandy AquaLink RS PDA, we have two
If you have a spa side remote unplug it at the outside control panel. If the problem stops it's the remote
Posted on Aug 30, 2009
SHANEOK
Pj Kiley
  • 21 Answers
SOURCE: Jandy Aqualink with IntelliFlo VS-3050
Jandy has an e pump.It would be cheaper to go that route.the Inteliflo is not compatible with the jandy system .If money is not a concern the pentair product is the way to go.
Posted on Oct 04, 2009
My jandy pda will not turn on after changing the batteries, any suggestions?
power aqualink system down all breakers turn off PDA then thurn aqualink back on then PDA should work if not need more info
Jun 29, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Why does my Jandy Aqualink alarm keep beeping?
if it has a aqua pure and it isnt working turn chlorine production to 0 and then get it fixed
May 24, 2014 | Jandy Aqualink - Rs32 One Touch Pool / Spa...
Jandy filter and pump with a aqualink. Pump
Once you turn it off their will be a heater override that will keep the pump running for five minutes so the heater can cool down. Be sure that you give it that time.
Feb 09, 2010 | Jandy AQUALINK RS TELELINK KIT
Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Sep 27, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jet blower randomly starts ...
most of the time this is caused by a faulty spa side controller. If you trace the line from the spa and disconnect it see if that solves the problem.
Jul 24, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink RS
Disconnect the spa side remote.
Jul 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Jandy AQUALINK RS TELELINK KIT  Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Dan Webster
Dan Webster
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
