Is this a range with the oven in the bottom and the hot plates on top. If so does it have an electronic timer/clock. If it does the electronic timer must be set to manual for the oven to work. If unsure turn the oven on and then adjust the mode control on the timer. If it is set to auto now and you can get it to manual the oven indicator lamp should light and the oven should work.
If it is a separate oven and cooktop there may be a separate power supply for the oven at the switchboard.
SOURCE: I have a Superba Built-in electric convection
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
