In the properties of the printer in Windows you will have a tab called maintenance. There you can select "cleaning" and "deep cleaning". You will want to run through those cycles several times and if the ink is still not coming through so you can print, you should let the full ink cartridge sit for about 20 minutes after that cleaning and then try again. With refilled ink cartridges this can be a game of patience. The alternative is to buy a new ink cartridge, but everyone knows those are costly. If the printer won't even "try" to print because the ink is low, press the "color" button to proceed after the alert.
