Question about Video Game Consoles & Games
I charged it, but when I push the power button it turns on then off by itself....what could be the prob?
Posted by katherinesan on
John Phillips
    Scholar:
    New Friend:
  • 70 Answers
Depending on the age, could be an old battery that can not hold the charge. Batteries also have memory, you are best to run the battery completely dead then charge completely. The only way to test the theory is to plug it in and see if it works while plugged in, if so it is the battery that can not hold a charge.
Posted on Feb 10, 2011
The tablet keeps turning itself off
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Jan 28, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
When i turn my ignition on all my lights and electronics are working however my car doesnt turn over could this be the clutch starter switch please help
Have battery load tested. it may still be bad. next test your safety switch with an Ohm meter, separated from circuit, push button the one that would be pressed with pedal arm. If nothing changes that's the prob. Another problem could lie with the starter solenoid or the starter itself.
Nov 03, 2012 | Cars & Trucks
Acer extensa 4420 shuts down right after you push power button
sounds like it doesn't have enough power, is it completely charged? you may want to make sure you're getting power from the charger itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 02, 2012 | Acer Computers & Internet
Nuvi 1250 will not turn on when power button is pushed.
that usually means that the unit is not charged. You need to connect it to a charger and wait a few moments, then check to see if it gives a signal that the battery is charging. If it is, then try pressing and holding the power button until it turns on. If you cant get a signal that the unit is charging when connected to a charger or to the computer via the usb cable that came with it then there is a problem with the battery itself and you need to contact the manufacturer for a possible replacement.
May 02, 2011 | Garmin nuvi 1250 Car GPS Receiver
I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Nov 30, 2008 | Samsung Yepp YP-T7JX MP3 Player
TOM TOM 910 won't charge/turn on
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Aug 10, 2008 | Tomtom GO 910 GPS Receiver
Its stopped.
dear check when u push the power button then it shows some light in key pad if then may be lose connection from cable or display ic is crrupted. other wise check software. mosty it prob from software first check for software.
Mar 20, 2007 | Motorola Mobility RAZR V3
Olympus Stylus Powers itself off
the power on button is located under de lens slyding thing, therefore probably is broken or just need to be glued to do that u will need to open the camera. the other u will need to replace a small battery on the mainboard. good luck
Dec 04, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Tom Chichester
john h
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
