Question about Canon imageCLASS D320 Digital Copier
How do you remove a paper jam at the site where the paper exits the printer (causing an accordian-style fold)
Posted by crcb_csw on
walter jansz
    Scholar:
  • 177 Answers
Turn off and unplug the machine you can open the front door open the exit side where the paper exits out gently remove paper the issue is caused by the upper fuser claws on the fuser unit they are worn you will need to replace them or replace the fuser unit assembly as other internal parts in the fuser may also be worn like the rollers
This should be done by a trained certified engineer
WHEN YOU TURN OF MACHINE MAKE SURE TO OPEN DOORS AND WAIT A FEW HOURS SO THE FUSER AREA CAN COOL DOWN CAUTION THE FUSER AREA IS VERY HOT
Posted on Feb 11, 2011
We have a imagerunner 210s. we just replaced the fuser unit and now when you try to copy, it copies the original but when it feeds through the exit door, it jams and when you open the door, the paper is...
please to see the claws. they are 5 claws which pluged on exit unit.
if you open the cover exit you will see them.
the shape like as a tigers claw. but more like as triangle.
they are move by spring, you try to moving. what are they work well?
problem usually cause
- the spring was loose or (you can plug or replace the spring)
- the claws have broken or (you replace a new)
- the claws dirty by crust toner. (you can clean up by your finger or your claw)
good luck.
May 22, 2011 | Canon imageRUNNER 210S Copier
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Paper gets jammed comes out accordian style
Remove the fuser /exit unit and clean the rollers and the fingers.
Oct 01, 2009 | Canon Office Equipment & Supplies
My printer folds the paper in the back accordian
check the drum unit and toner unit, also check on all rolls inside the printer.
if still not working you can send it to me to fix it for you.
Jul 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jam at output on the Imagerunner 1310
I have a solution. Take a baseball bat and knock the crud out of that ******! That will fix the problem of not having a door! Thus it will make a verrrrrry easy opening to get the paper out! :-D
Feb 04, 2009 | Canon imageRUNNER 1310 Printer
Konica Minolta Di251
Could be that it is printing a legal print on letter paper. This causes a timing error which appears as a jam. If it is accordion folding behind the exit rollers the paper could be hanging on the exit sensor flag. If it accordian folds in the fuser then the fuser needs replacing.
Jan 04, 2008 | Konica Minolta DiALTA Di200 Copier
Canon imageCLASS D320 Digital Copier Logo
old marine
old marine
efs_perpends
efs_perpends
