It could be a thermal fuse from what I've read.
I suggest you contact Aroma directly:
http://www.aroma-housewares.com/kitchen/appliances/contact-us.html
SOURCE: My oster 3071 rice cooker ''E2'' error
it happened on my oster 3071 the error e2 just appear the only that i did was open it and I found out that the blue wire which is connected on the lid is cut so i just reconnect the wire and stick it together using souldering iron and presto it is good as new again
SOURCE: I have an aroma rice cooker model #arc-150sb c1
Thermal Fuse Problem.
If there is no heat/power, check the continuity o the thermal fuse( white resistor type in the internal wiring connections ). Unscrew and open the cooker at the bottom side.
Replace it w/ similar temp. value.
DON'T SOLDER IT!
Hope that helps you out!
