Question about Bunn A10 Coffee Maker
My brewer leaks from base of the brewer - Bunn A10 Coffee Maker
Posted by annettlot58 on
Anonymous
    New Friend:
  • 91 Answers
Either leaking from tank lid or fill basin.You will need to take of top of brewer to verify.Parts and breakdown available at the Bunn website.Contact customer service at Bunn.I know at one time they would replace the brewer at a discount rate.
Posted on Feb 10, 2011
How do I fix a leaking Bunn Coffeemaker model NHBX-B?
This is a home model pour over. Overfilling is the most common cause of leakage as there is no plumbed in water line. You should only pour in the amount indicated on the decanter. If it is overflowing, check if you have the right decanter as someone may have used an old pot from a larger brewer. Say there was a 12 cup pot around and now you have a 10 cup brewer.
* carefully pour water to the inner fill line. You will probably see a ledge or spill off hole on the inside of the fill tank. Some units will spill out the back, others may spill back into the drip funnel. Note at what point you get near the spill level and note how much is left in the decanter. The amount left is your over flow.
* If you want more accuracy then use a measuring cup and count how many cups are needed to fill the brewer.
* Unplug any brewer that has water coming from the base. Dry up the area and drain the brewer. Dry off and let sit to completely dry out. Refill, note any leaks? If okay then plug in and brew as normal.
* still having problems? Contact your vendor for service.,
Aloha, ukeboy57
Jun 30, 2015 | Bunn NHB Coffee Maker
Commercial Bunn CWTF-DV-3T is leaking water from the top right corner of the machine and now at the base behind the bottom burner when you start a pot of coffee
water tank inlet in the top possibly limed up causing pan to overflow. remove top, use screwdriver or deliming spring to poke through the drain nut in the pan. should work fine now
Feb 17, 2014 | Bunn 10 Cup Home Coffee Brewer
Leaking water
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Water leaking while the brewer just sits there? Leak in the tank. Call for service.
* water leaks only while pouring? Then your pouring to fast. Wait for the water to drop before pouring in more. If it still leaks even while pouring slowly then there is a leak in the fill tray. Call for service.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Jan 12, 2014 | Bunn GRX-B
It leaks
Here is a tip that I wrote about Keurig coffee brewers and the Keurig leaking problems
Keurig One Cup Coffee Brewer leaking
heatman101
Aug 28, 2011 | Keurig B70 Coffee Maker
I have a puddle of water that is leaving out of the coffee maker from the bottom. (underneath)
Here's what I discovered about my Keurig B60: The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Aug 28, 2011 | Keurig B60 Coffee Maker
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
Brewed coffee mess
You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
Aug 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn A10 Coffee Maker Logo
196 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
