SOURCE: Camera will not turn on Polaroid i533
I even tried installing new batteries, removing the memory card and still got the same message.
I was told by the Polaroid Warranty department to mail back "defective" camera for a replacement....just make sure you have your receipt.
SOURCE: is the polaroid i533 camera
No, the polaroid i533 camera is not compatible with sdhc memory cards. Use only SD cards.
SOURCE: my Polaroid i533 digicam won't turn on
Try checking to see if the lens is a little crocked, look at it real closley.If it is then try and pop, or bend the lens back into place, and then turn your camra on and the camra may work propelry.
I had the EXCACT smae problem, and it worked for me.
So it may hlep you too.
SOURCE: i733 Polaroid camera will not turn on
well I HAD THE SAME PROBLEM ALL I GOT WAS A BLACK SCREEN & 3 BEEPS,SO GOT A LETTER OPENER AND STUCK IT IN THE SPACE BETWEEN THE ZOOM LENS A FEW TIME VERY CAREFUL PUSHING DOWN THE POWER BUTTON AT THE SAME TIME AFTER A FEW TIMES THE LENS BECAME UNSTUCK..JUST JIGGLE IT A ROUND A LITTLE BACK AND FORTH WITH A LITTLE FORCE.I HOPE YOUR CAMERA WILL START TO WORK AGAIN LIKE MINE DID.
