You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Testimonial: "That worked, thank you so much."
That worked. Thank you so much.
