Question about Gateway NV55C03u Laptop
When i try to clean-up temp internet files using disk clean-up in hard drive properties it tells me there is an error in the memory dump files
  • Anonymous Feb 11, 2011
    I already know how to clean up files from my browser. I just wanted to know how to get rid of the error message and what the error means. I se now that i wasn't clear on that when i asked the question, sorry. If you could help me with this it would be cool.. Thank You!
Bill Yee
    Sergeant:
  • 236 Answers
It is better to use your browser to clean-up temp internet files.
For Internet Explorer do the following...
1. while in Internet Explorer
2. click on Tools in either the Menu or Command bar
3. click on Internet Options at the bottom of the pop-up menu
4. on the Browsing history part of the Internet Options window
5. click on the Delete... button
6. on the resulting Delete Browsing History window
7. check-mark Preserve Favorites website data
8. check-mark Temporary Internet files
9. make sure everything else is not check-marked
10. click the Delete button at the bottom of the window
If you want to delete other items, check-mark them prior to pressing Delete button.
If you want to manage Temporary Internet Files click on the Settings button
and set appropriate options in the Temporary Internet Files and History Settings window.
Finally, click OK when exiting to save the changes otherwise click the Cancel button.
Posted on Feb 10, 2011
  • Bill Yee Feb 12, 2011
    Disk Cleanup always scans the entire disk to create its list of files that you may want to delete. If you are just wanting to clean-up temporary internet files, this may take significantly more time than just doing it through your browser where you can specify exactly what you want done with the different type of temporary internet files. Also, because of Disk Cleanup's scanning of the entire disk every time it is used, it can generate error messages or even fail should it encounter any problems anywhere on the disk. So running Disk Cleanup can give you a sense of the health of your disk but that is far different from your stated task to clean-up temporary internet files. Suggest that if the error message only occurs during file deletion and not during the scanning, you could uncheck everything except for temporary internet files and see if the error message occurs. If it does not, then the problem is in the cleanup of one or more of the other group(s) of files that you had unchecked. Then you could rerun Disk Cleanup and just check each of the groups one at a time to isolate the offending group(s). If you are successful in isolating the group(s), then make sure they are unchecked everytime you do a Disk Cleanup and you won't get the error message.
System is very slow both on WIndows and Linux platforms
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 18, 2013 | Computers & Internet
How to Free up low disc space on asus 901?
  1. Open Disk Cleanup by clicking the Start button. In the search box, type Disk Cleanup, and then, in the list of results, click Disk Cleanup.
  2. In the Drives list, click the hard disk drive that you want to clean up, and then click OK.
  3. In the Disk Cleanup dialog box, on the Disk Cleanup tab, select the check boxes for the file types that you want to delete, and then clickOK.
  4. In the message that appears, click Delete files.
Nov 25, 2011 | ASUS Eee PC 901 XP Notebook
Slow
Your windows partition should have at least 1GB empty space. More is welcome. If not try to remove the files & transfer them onto another partition. It is recommended not to put your data files on the windows partition. Remove all the files on the desktop & dump them in a separate folder on a partition. Remove any screensaver/ themes with animation that you are using. Keeping files on the desktop slows the laptop. De-fragment your hard disk. Right click on hard disk partitions. Goto disk cleanup. Select the files which are unwanted. Delete temporary internet files, cookies, history accessible from the browser's options. After carrying out these procedures your netbook shall be fast. If not, check your physical memory& the memory shown in system properties. If it does not match then you need to change your affected memory module.
sonsunny
Jul 04, 2011 | Acer Aspire One D255 Netbook
Critical error! Windows can't find hard disk space. Hard drive error -- Damaged hard drive clusters detected. Pruvate data at risk!....What should I do ?
Try deleting all files within the following locations: (In Windows Explorer (not Internet Explorer) click "Tools" and select "Folder Options" then choose "Show hidden files" and take the tick out of "Hide protected system files")
%UserProfile%\Local Settings\Temporary Internet Files\
This is the action of some form of malware, masquerading as Windows Security Center. It roots itself in the current user's temporary data folders and as far as I know, doesn't affect all users.
It is also a hidden process but as far as I know, doesn't execute any particularly malicious code, just a really annoying notification (which you'll notice changes).
Nov 02, 2010 | Microsoft Windows XP Professional with...
Laptop shuts down begining dump of memory runs check disk
Your hard disk has developed errors.
This might be caused due to damaged files on your hard disk, or a program you recently installed which may have some errors.
If you recently installed a program, that does not work well with your computer, you might consider uninstalling it.
You should also consider performing a disk defragmentation to reorganize file on your computer.
To perform disk defragmentation, go to your "My Computer"
Select your Local Disk drive, then right click and select Properties.
Click on the "Tools" tab, then click on "Defragment Now"
After that, select the Local Disk C drive, then click on Defragment.
Thank you for using Fixya,
Kenneth
Feb 15, 2010 | IBM ThinkPad T30 2366 Notebook
I need to change my default Download driver to the D drive as my C drive is always full, I've tried to move some of the programs from the C drive to the D drive but it says that some of the files may not...
Try the disk cleanup in the disk properties (right click the disk icon).
You can really free up a lot of space by deleting temp files, memory dump files and all restore point but the last. The last thing you only want to do if your system is running stable of course.
Also make sure to defrag after disk cleanup to maximize the efficient use of the free space.
Dec 14, 2009 | Lenovo IdeaPad Y510 Notebook
FREE UP HARD DRIVE SPACE
Hi! Your 3 Gigs of memory have nothing to do with your disk storage. You may try freeing some disk space by doing the following:
Clean up your recycling bin by selecting the Empty Recycle Bin option, after right clickin on the icon.
Clean up the All User's temp directory, usually within your Windows installation drive-> Windows folder, called TEMP folder.
Clean up your own TEMP folder, usually hidden and found within your own user name folder. To make this folder visible, in File Explorer, go to Folder Options, and find the entry that reads: Hide system files. Uncheck the option. Make sure you reset it after you're done.
A little riskier is to try to resize your virtual memory, or the amount of disk space that Vista (and other versions of Windows) uses to emulate physical RAM, when you have exhausted it.
You may also save disk space by sacrificing the Hibernation feature by disabling it. If you do this, by going to the Advanced Settings of Vista, under System, uncheck the box next to your drive, and while having Hide System Files also unchecked, you can physically delete the file, usually found at the root of your main drive (usually C:) Note: For this change to take effect, you will have to restart your system with a cold boot.
Try buying some software similar to Norton Utilities (a reduced of it is available in Norton 360) that will defragment your drive but will also clean up stray and orphan files left behind by improper uninstallation of other software and temp files left behind when an application like Word, or any other, crashes.
Oct 08, 2009 | Computers & Internet
I keep getting a system dump/blue screen. i tried
You might have bad memory, a corrupted registry file, corrupted system files. Try starting up in Safe mode then backup your data. Goto My Computer and right click on the hard drive and select properties. Goto Tools tab and select error checking of hard disk on startup. Might need to reinstall Windows
Aug 05, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Maxtor one touch iii mini
You have a possible corrupted file. Open My Computer and right-click the drive icon. Click PROPERTIES in the menu. Click TOOLS. Click CHECK NOW. Click a check into the AUTOMATICALLY FIX FILE SYSTEM ERRORS box. Click START. The OS may tell you a reboot is required.
If all else fails, dump the data to some other storage device and use DISK MANAGER to delete the partion, make a new partition and format.
Nov 29, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Gateway NV55C03u Laptop Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
