Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Phone just went dead after 2yrs normal used. It open in split seconds and off again. I change with new battery and same thing. Not sure if thebattery is being charge, no indication. I plug-in and turn-on, same result. Thanks
Posted by romvilla on
Natarajan Ramasamy
  • 944 Answers
This is the fault with the battery connector IC.Since you have changed the battery and still the problem persist then you have to check the IC.Use ohm meter to do continuity testing on the board and check the connector IC.You have to replace the or re-solder the IC based if it is loose or damaged.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 10, 2011
Water damage
Remove the battery and let the unit sit for a day or two. It takes a lot longer to dry out than it seems. If it doesn't work after that amount of time, the water probably did permanent damage. The cell company's regular warranty covers defects, but their premium insurance should cover even water damage. If they don't cover it at all, the repair cost probably isn't worth it if you can get a deal on a new phone. Definitely worth a shot to call or stop in your cell company's physical store and chat them up.
Feb 20, 2008 | Motorola Mobility RAZR V3
My 2005 kai will not start and all the lights are out on dash
It sounds like you just have a defective battery, new sealed batteries do this exact thing. I have had this happen on my personnel cars and trucks about 5 times over the years. Also make sure the battery cable are clean and free of corrosion.
Jun 30, 2016 | Cars & Trucks
2yrs old. Went thru 3 sets of batteries to get 20 pictures. Dead again. What`s the story?
Sounds like you have a short in the wiring. This is repair shop stuff, or buy a new camera time. Usually, if it is a point and shoot , it is not worth sending for repair as you'll playas much as a new camera is worth. I would look for a new camera, personally. Good luck.
Oct 20, 2014 | Cameras
2009 Sportster 1200 Custom. 2 year Battery was dead, I charged it got one ride and it went dead again. I changed the Battery Sunday and rode for about an hour, parked for about 3 hours and rode again for...
Check all the fusses and the bulb for the check engine light.
If the fuel pump wasnt running it wouldnt start at all.
I think you have a bad voltage regulator and your engine light would be on if it worked.
Sep 17, 2013 | Harley Davidson XL 1200 C Sportster Custom...
The 12 volt battery(LUCAS 065/3) on my FORD FIESTA 1100cc is 4 years old, in that time i have only driven 1,600 miles as my journeys are usually very local. I make sure i use the car twice a week to keep...
Running so few miles has accelerated the aging of the battery - the battery never had a chance to fully recharge in such small trips -  so now you have to replace it a year sooner than usual.
Just replace it.
Aug 28, 2010 | Ford Escort Cars & Trucks
Dell Wireless Mouse dead
now mouse is open & clean by isoprpile & check battery conector after check now mouse its working.
Aug 25, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Cell got wet
as the battery is dead you must buy a new battery and insert it ...
surely it will work ...
i think you may get some screen problems after switching on ...
if so remove the handset & screen too and adjust it again ....
this may happen if there is any water traces ...
Apr 15, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Relax
Relax
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
