SOURCE: PhotoShop Elements 3.0
I already found a solution. I am not home at the money so I cannot tell you exactly what I did, but there was something under the system portion of Vista that I had to add PrintMaster to so that it would work. I am able to now use the program.
Thanks!
SOURCE: Clips out of time after recording.
It's got to be either latency or something causing the movement. I doubt you'r making the same mistake with your mouse every time, so my guess is a program on your machine if it isn't the latency thing.
Here are some questiosn for you:
SOURCE: cannot install photoshop elements 6 in vista home edition
There is a problem with the auto-extractor.
Manually extract the files from the downloaded file using Winzip
and extract to a new folder. Then run Setup.exe from that folder.
Also, make sure that your Temp folders have been cleared out.
The latest version of WinZip may be downloaded from http://www.winzip.com
SOURCE: I purchased a refurbished computer to be used for
maybe the CD rom dont read properly the CD installer you can try to use another CDROM or YOUR CD installer is damage...
