Remote Start System  Logo
Posted on Aug 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installing the Viper 5101 on a 2004 duramax diesel. Does this system have a direct Glow plug wire to connect to instrument cluster light? If so, is there any specific connection site on the wire? Does this system have a seperate remote for starting the vehicle, and if so, is there another system that will work with my truck that has the remote start and door lock and unlock on the same remote?
Donald Pera Deane
Level 3:
  • Viper Master 384 Answers
  • Posted on Aug 14, 2017
Donald Pera Deane
Viper Master
Level 3:
Answers
384
Questions
0
Helped
160695
Points
1901
Glow Plug lol thats a remote l (more Info )
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Dec 04, 2008
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Anonymous
  • 50 Answers
  • Posted on Aug 14, 2009
SOURCE: Viper SST 7701. I replaced
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
Anonymous
  • 5 Answers
  • Posted on Oct 09, 2009
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Anonymous
  • Posted on Nov 25, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Anonymous
  • Posted on Nov 27, 2009
SOURCE: How do I lock my keypad
there is a way to do it in the manual which can be found at www.viper.com/support.... i did it by mistake and now can't figure out how to turn it off
89 Ford E350 Diesel - two problems 1) no power to instrument cluster, 2) diesel will not fire off without starter fluid...but the glow plug solenoid does click and wait light goes off
You should never use starter fluid when the glow plugs are hooked up. It can cause severe engine damage. You probably need to replace all the glow plugs and the glow plug controller.
Glow plug light flashing
the glow plug are used to heat the fuel on start up only, as a diesel uses compression instead of a spark (from the spark plug) have you try checking the connection on the glow plug, or changing the glow plugs themselves?
2answers
Need to know firing sequence of glow plugs on a 2006 chevy 2500 hd duramax diesel engine
I am told the glow plugs heat up in "firing" order, also the Duramax uses a intake air heater to warm the air on cold starts.
1helpful
2answers
I have a 2003 chevy duramax diesel gauge panel and digital read out quit working. check engine light glow plug light and turn signal lights still illuminating on dash checked fuses and connector and pins...
i own three gmc trucks years 2004 2003 and all three trucks have dash problems get ready to spend 400.00-800.00 on the problem or take to a mechanic and have him wipe all codes clean will solve problem for a short while
2003 GMC Seirra Duramax Deisel won't start
If it cranks and won't start then it is probably your glow plug system which is used to help with starting as diesel engines have no plugs and rely on compression. It also helps to run a lighter oil in the winter so it will crank faster. You can ohm out the plugs to see if they are broken. I am not sure of the wiring on the GMC but usually diesels have several wired in parallel
I have a 2003 gmc sierra duramax diesel and im in need of a glow plug diagram?
The diagram is simple each glow plug is connected in a series circuit like this -0-0-0-0-0-0-0 that's a in-line 6 for a V-8 it would look like this
[-0-0-0-0
[-0-0-0-0
and the plugs would be hooked up on the back then if you follow the wire to the glow plug relay you will find that the relay has four wires one to battery one to the glow plugs one to the ignition switch and one to ground in the box. If you want you can purchase a manual for 5.99 on-line. and it covers the three fuse-able links for this system and the new Glow plugs available for this truck here is the web page. http://www.wiring-diagram.com/?gclid=CMuAvJ3Ql58CFQZfagod0jpAxQ
2answers
Viper 5901 Starting issues
i need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Cigarette lighter fuse
Here is the fuse relay diagram:
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A). Source(s): http://forums.tdiclub.com/showthread.php?t=122606 fame !
2helpful
2answers
2003 Volkswagen Golf Problem
it should be number 42
MKIV FUSE LIST
8. Open
17. Open.
42. Radio (25A).
S179. ABS (30A).
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
