The sound cuts in and out and has a grinding noise. Also everytime I restart the computer I always have screen problems. The windows live chat and gateway music gadgets try running causing the screen to flash. It takes forever for the desktop to come up.
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
Test or replace your PSU power supply unit if the units fan is not working its faulty
one bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Posted on Feb 09, 2011
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
Downgrading for windows 8 to xp
Hello, in the bios there is a setting called sata mode, you should be able to change it to ide mode, save and restart the installation of Windows XP. Hope this helps
Youtube
Facebook
Chat Live With Remote Support
Feb 22, 2013 | Computers & Internet
Alienware aurora r3 diagnostic lock
Sounds like a complete new install of windows is in order. Sounds like you may have had a very bad virus that has messed everything up. But very well could have been something else things like this are not always the result of a virus
Aug 30, 2012 | Dell Alienware Aurora-R3 Gaming Desktop...
I bought this Acer aspire 7535g laptop off of my mum's friend which was in great condition when I bought it. The sound was perfect. Every driver was up-to-date. However now... 8 months on, the sound...
You can try booting a live linux CD or thumbdrive and see if that gives you sound. That will give you an idea if it's Windows or a hardware problem. If it's a windows problem try uninstalling and reinstalling your drivers. If that doesn't work keep searching around or just try a fresh install of windows.
Aug 27, 2011 | Computers & Internet
How to turn it on to chat at windows live messenger
Windows live messenger already comes loaded to chat with anyone of your friends/associates. If you are not able to access a chat window after double right clicking on a contact, then you may need to remove messenger and reinstall. After removing the messenger, restart your computer, then access the windows messenger from the website, and reinstall.
Nov 15, 2009 | HP Pavilion dv6000z Notebook
Hi, my dewalt 12 inch double bevel, is making a
This sounds like a problem with the electric brake on the motor.
Aug 30, 2009 | Dewalt Heavy - Duty 12" Double - Bevel...
Windows live messenger voice chat not working. the computer rings and answers but no voice is heard
This problem is due to network traffic,after answered or connected u should wait for 2 to 4 mins,it will works in some times otherwise stop and reconnect the voice chat. if the problem is remains longer then restart the windows live messenger.
Aug 15, 2008 | Computers & Internet
I've bought a logitech quickcam communicate STX. When I installed it first it worked fine. Someone unpluged it from the usb port and it wouldn't work. I re-installed the drivers and it was fine again but...
The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Feb 25, 2008 | Logitech Webcam
Computers & Internet Logo
k24674
