Question about Konica Minolta bizhub C250 All-In-One Laser Printer
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is always different, so its not a consistent smudge, its usually some wording from a recent document that has printed.
Posted by mike13660 on
taminol
    Sniper:
  • 62 Answers
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Regards
M-PRESS.BIZ
Posted on Feb 23, 2011
Testimonial: "Thank you for the advice. You were 100% correct, problem solved!!!!!!!"
Can't figure out how to duplex print flipping on short side
check print properties on computer, double side and left binding
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 25, 2014 | Konica Minolta bizhub C250 All-In-One...
No print on copy in bizhub konica 280c copier
replace the yellow image unit
Dec 17, 2013 | Konica Minolta bizhub C250 All-In-One...
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
I have the bizhub C352 - I want to print the utility/counter (meter readings). How do i do that. Previous machines had me go to Utility - admin management - copy track - Copy track data - & hit the...
to print meter readings perform these steps. 1-press "utility/counter" 2-press "details" 3-now at the left side of the screen you will see a "print" button, press it and get your copy.
Oct 20, 2010 | Konica Minolta bizhub C250 All-In-One...
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
757 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
