Question about HP P3015 Laser Printer
HP P3015 suddenly printing very slowly - about a page a minute
Posted by danny845 on
Seeker5211
    Genius:
  • 1,089 Answers
If you unplug the cable from the printer to the PC and print the MENU MAP, does it print slow or at normal speed?
If it prints slow, try following the directions below.
If it prints at normal speed, try removing the printer from the print queue and reinstalling it. Also, download the PCL5 drivers and reinstall it.
Good Luck.
Print a MENU MAP and a CONFIG page.
You will need this info to put the settings back in the printer.
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the CHECK MARK button. Continue holding
down this button until all three device control-panel lights flash once and then remain on. This
might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the ^ button
until COLD RESET is highlighted.
4. Press CHECK MARK . The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
COLD RESET sets ALL control panel menu items, including network settings back to factory defaults.
This is where the MENU MAP and CONFIG info come into play.
Posted on Feb 10, 2011
LaserJet P3015. Why is it printing dark background?
Hi Boateng Samuel,
I would be happy to help you with your P3015. Although the enterprise printer models are out of my support scope, I was able to find you the appropriate document specific to print quality. Please use the following document to troubleshoot the issue:
HP LaserJet P3015 Printer Series Solving Print Quality Problems
Best of luck, I hope this helps.
I work on behalf of HP.
Jul 17, 2015 | HP Office Equipment & Supplies
I printed several documents and then got a 51.10 error on my HP P3015. It tells me to turn the printer off and on, but this does not resolve the issue.
This error means that the laser scanner assembly has failed. That you are able to print a couple of pages is a pretty common symptom. Eventually it will fail entirely, so time to replace it. Part Number should be RM1-6322-000.
Aug 26, 2014 | HP P3015 Laser Printer
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
Hp laserjet p3015 not printing
The printer will have a message in the screen saying roughly how many pages are left in the toner cartridge if the toner is running low. Try printing a "configuration page" by pressing "ok", arrow down to "information", arrow down to " print configuration page", then press "ok". If this page prints you still have toner left.
Dec 12, 2012 | HP Laserjet P3015X Printer
My HP 3015P will no longer print PDF files. This is a new issue. Anyone have a solution?
I'm having the same problem with three networked P3015 printers on a Windows 2003 server. They stopped printing PDF files last week. The universal PS driver from HP works, but it's a pretty ugly solution. I'd like to know why the PCL driver just stopped working.
Btw, we're printing from Acrobat 9.4.2. Word, Excel, and other office printing is fine still.
Feb 17, 2011 | HP P3015 Laser Printer
How do I stop the duplexing on the P3015. CD installed a P3010 driver. We have change the printing preferences to NO for duplexing but it still duplexes.
Make sure that in both the printer preferences no multiplexing is set up and that no multiplexing is set up in the the printing preferences of the software you are printing from
Dec 23, 2010 | HP P3015 Laser Printer
51.10 ERROR
i cant print my document my hp laserjet p3015 print display error message 51.10. please slove this imdy.
Dec 13, 2010 | HP P3015 Laser Printer
Hp laserjet p3015 pausing after 5 or so pages whilst printing large amounts, the printer prints 5 pages then has a pause before starting printing again, this can can make printing very slow i've...
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
Aug 16, 2010 | HP Office Equipment & Supplies
HP P3015 Laser Printer Logo
efs_perpends
efs_perpends
k24674
