Question about Black & Decker HC3000 Handy Chopper Food Processor
Need bowl for food processor FP2510SKT.. Purchased at Canadian Tire could never get the big container to work , finally discovered the spring was broke and wouldn't lock into place. Lost receipe couldn't return it.
Posted by jo_annmac on
Lance Hill
    Genius:
  • 1,739 Answers
Available parts for these machines can be found at these links:
Black & Decker FP2510SKT Food Processor
http://www.directpartsandproducts.com/food-processors-fp2510skt-c-1_378_394.html
Black & Decker HC3000 Handy Chopper 1.5 Cups Food Processor
http://www.directpartsandproducts.com/food-processors-hc3000-c-1_378_408.html
Posted on Mar 21, 2011
Need a product manual
Try going here:
Food Processors Product Manuals Cuisinart com
Look for a machine with the same style / bowl size as yours if your specific machine is not available. You can even download more than one to get additional recipes!
The main important thing if you have an older machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle.
If you put the top on backwards it won't work correctly, and you might break the catch when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Jan 19, 2014 | Cuisinart DLC-7SFP Pro Food Processor
I have a Cuisinart DLC-8S TX Pro Custom 11 Cups Food Processor that I purchased in spring 2004 and used only sporadically. Last week, I burnt the motor by using it to make fondant. Big mistake. I take...
If you already have a lot of attachments for this model, I would purchase a used motor unit. I got a complete setup at a yard sale minus the work bowl cover for $3 as a spare, and often see them at thrift stores priced quite inexpensively. You could also check ebay. Motor units routinely go for less than $25 including shipping. I'm pretty sure most dcl-8 series motors will work with you bowl and attachments. I like the quality of the older units better than the newer ones. And if you watch ebay closely, you can pick up a lot of pieces really cheaply. Good Luck,
Marc
Oct 21, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
Need replacement bowl for Black & Decker Food Processor CFP10
Contacted customer service and part is discontinued. Purchased a Cuisinart from Amazon.com.
Aug 31, 2009 | Black & Decker FP1400 Quick N Easy Plus...
Light is on but blade will not turn
You have a bad sensor switch, when you put the bowl. Locate the sensor switch and replace it.
Jul 23, 2009 | KitchenAid KFP740 Food Processor
Motor won't turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Bowl handle doesn't make connection
I had this problem, I finally stuffed a tiny piece of tin foil into the hole the spring is supposed to go into to activate the machine. It works, but it is always on, even if the bowl is not locked into place so I have to be careful. I just store it unplugged.
Nov 16, 2008 | KitchenAid KFP750 Food Processor
Can't get bowl off.
It locks pretty tight. I use the heel of my hand to tap the handle back the opposite way as when you lock it on and this unlocks the bowl.
Oct 31, 2008 | Hamilton Beach Big Mouth 70590 Food...
Cuisinart food processor DLC 8 Plus - can't unlock new bowl
I just had the same problem! I gently tapped the the bottom of the handle with a hammer in a clockwise direction. It finally unlocked and is now working fine. Good luck!
May 11, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
It won't start
The power lights go on put the machine does not run.
Nov 22, 2007 | Cuisinart DLC-5 Food Processor
Black & Decker HC3000 Handy Chopper Food Processor Logo
388 people viewed this question
Top Black & Decker Food Processors Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
