Question about Sega Genesis Console
Hi I bought a sega genesis console unit, the red LED doesn't light when i switch on the power, i assumed the power part of the motherboard had cold solder so i resoldered it. The power still doesnt work though any suggestions?
Posted by c_mour on
Anonymous
  • 496 Answers
DEAR FRIEND, YOU WILL HAVE TO TRY USING ANOTHER ADAPTER FOR YOUR GAME.
Posted on Feb 09, 2011
When I try to hook my Sega Genesis up to my TV, why does nothing happen?
you should have a red light and if its on it should be working. I would just go on Amazon and buy a AV connector for the system, no need to use RF like its 1989 :)
Dec 31, 2015 | Sega Genesis Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
REPLACING LED AND INSTALLING NEW WIRES FROM THE MOTHERBOARD TO THE LED GENESIS 1 CONSOLE
Well there are video;s on youtube that would be able to help you out with this too.
www.youtube.com
Feb 03, 2011 | Sega Genesis Console
Help connecting a Sega Genesis 16bit system!
What you will need to do with the RF cable is to take your incoming cable thast goes to your TV and screw it into one side of the RF box. Then the adjacent short cable wire that is on the other side needs to be screwed into your TV. The long end of the cord plugs into the back of the sgea unit. Good luck! Any other questions, feel free to ask.
Nov 07, 2009 | Sega Genesis Console
Power, But No Picture!
Try moving the a/v or rf cable in the back of the genesis
Mar 03, 2009 | Sega Genesis Console
Power Problem
um take it back
Feb 22, 2009 | Sega Genesis Console
Sega genesis
don't panic
sometimes the LED goes on the Megadrive
so try to tune it in anyway. (clean a game and put it in)
also sometimes you can get a "Dry joint" at the power port at the back of the megadrive.
this is fixed by unscrewing the megadrive and a little solder on the each of the 3 joints.
May 19, 2008 | Sega Genesis Console
Sega Genesis Console Logo
Top Sega Video Game Consoles & Games Experts
Aron
Tom Chichester
ray gallant
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
