SOURCE: Bosch Nexxt Electric dryer tumbling but not
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
SOURCE: Bosch Nexxt 800 series dryer E01 error
If you are using dryer sheets...stop. They clog your linter filter. Use windex to clean the filter and a soft bristle brush....also check to ensure your dryer vent is clear using a shop vac to clean or a vent brush.
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
SOURCE: my bosch nexxt 500 series electric dryer is not
We had the same problem. Cleaned out lint filter and still no heat. We took off the back (lots of screws and had to take top off to get back off). If you are looking at back - at the bottom left there was a red reset button and it clicked when we pressed it (when we pressed it again there was no click). Worked fine after. This solution came from internet. My brother-in-law changed setting to "extra dry"- we usually just used 20/40/60 setting. I think it overheated.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
