Question about Microwave Ovens
HOW DO YOU CHANGE A LAMP ON A SWAN MICROWAVE - Microwave Ovens
Posted by kevinspurs on
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave bulb
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
Manual
Swan is now owned by Littlewoods. You can contact them here. The Swan helpline is at 01733 404 709.
Jan 30, 2013 | Microwave Ovens
Need instruction manuals for swan breadmaker sb1010nb. also swan slow cooker sf11020n
check out the swan web site for a downloadable instruction manual
Sep 11, 2010 | Microwave Ovens
I did not fet a manuel with my swan combination
GO TO MFG. HOME PAGE,SEE MANUEL SECTION..
THEY WILL HAVE YOU MANUEL AND JUST PULL IT UP AND READ OR PRN IT OUT....
FRED
Feb 14, 2010 | Microwave Ovens
Need manual for swan swm900c microwave
Aug 19, 2009 | Microwave Ovens
Where can i get the instruction manual fo the swan sm2050 microwave
Aug 03, 2009 | Microwave Ovens
Swan sm115 microwave
Apparently Swan is now owned by Littlewoods. You can contact them here.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 28, 2008 | Microwave Ovens
Reset my clock
Normally you press Clock, then the numbers, then either Clock again or Start.
If that does not work, you should call the dealer or store where you got the oven to see if they have a contact number for Swan.
Jan 21, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
john h
acmservice
Are you a Microwave Oven Expert? Answer questions, earn points and help others
