Question about Canon PIXMA MP600R All-In-One InkJet Printer
Getting error code on printer screen A600 why does
Getting error code on printer screen A600 why does this accur
Posted by jlr3_john on
Anonymous
    New Friend:
Mine kept doing that. My dad found website where lots of people had turned it upside down, shook it and then was fixed, so we tried it and it actually worked!! Now is printing again and no error codes!! Worth a try!!
Posted on Feb 28, 2011
Error Code
Hi Steve,
Please try Josh's Lab solution (on YouTube):
Josh Lab 9 Canon Printer Error 6A00 Fixed
G'Luck !
Apr 11, 2014 | Canon Office Equipment & Supplies
I did have a paper jam a couple days ago and am now getting a a600 error code on my mp530, any suggestions on how to reset this?
A600 is a generic error message of a Canon Printer that points out to a hardware issue. No specific part is referred to so it's difficult to tell. You need to take this to the nearest service center to be checked and repaired, as what Canon techs advise.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment in return. Have a good one!
Jul 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
A600 error or Canon Pixma MP780. Now it won't even turn on...like no power is getting to the printer. What's up?
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 19, 2010 | Canon MF4150 Laser Printer
The cartridge holder won't slide along - just says error message A600. Had just replaced a cartridge, and it did work at first, but not 5 mins later
Hi there
Error A600
Mar 22, 2010 | Canon MP610 Photo All-In-One Printer
Pixma MP610 Error A600
The code is for a cartridge lift mechanism error. Either the sheet feed unit, logic board or pr lift shaft assembly.
Feb 24, 2010 | Canon PIXMA MP610 InkJet Printer
The printer screen shows "Error A600" and the printer will not work - what can I do?
Hi there
Can only try.
Error A600
Feb 11, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Oct 07, 2009 | Canon Office Equipment & Supplies
I receives error message A600 on my printer
6A00 fix
There is a sponge to the right of the ink cart that gets pushed up to prime each ink cart. The sponge then drops back down when finished. The problem is that the sponge gets stuck up. Just give it a tap and it will fall down, turn off then on and all fixed
Oct 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP600R All-In-One InkJet Printer Questions
Canon PIXMA MP600R All-In-One InkJet Printer Logo
old marine
old marine
efs_perpends
efs_perpends
