Question about HEWLETT-PACKARD Garden Dreams Pavilion dv5-2129wm Notebook
My wife has a pavillion dv5-2129wm. The touch pad will occasionally get an amber light in the upper left corner of the pad. This seems to indicate that the touchpad has been turned off. The pad will not respond while this light is on. The first time, restarting the unit cured the problem. Now restarting will not fix the issue. How can I reactivate the touchpad?
Posted by davncari_den on
Anonymous
Double tap on the pink flower under the amber light this will turn it back on and when you want to shut it off again do the same thing.
Posted on Feb 27, 2011
H pavilion dv5 2134ca touch pad
The button you are looking for should actually be right on your touchpad. It's in the center at the top of the pad. Just press it and your light should go blue
Mar 24, 2014 | Computers & Internet
How do I disable the touchpad on my hp probook 4530s?
03-27-2013 FINALLY A SOLUTION THAT WORKS TO DISABLE HP 4530S touch pad:
Clickity click on Control Panel/System/Device Manager/Mice/Synaptics PS2/Driver/Update Driver/Search Internet for latest driver.
It should find and update with driver dated 01/10/2013 which is driver version 16.3.9.0
HOORAY! Double click on the upper left hand corner of the mouse pad, the light comes On indicating that the mouse pad is OFF - and it works just like HP said it would two years ago. Knowing HP, who knows for how long it will work.
This works on Windows 7 - on other systems your milage may vary.
Dec 11, 2011 | HP 2133 Notebook PC
How can deactivate the pad?i dont want to click with a double touch...thanks
To turn the TouchPad on/off, quickly double-tap the TouchPad off indicator (the yellow LED) at the left top corner. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
This would disable the touchpad completely. Also, if you wish to disable just the double-click through double-tap, you can do this by going to the mouse/touchpad options from the control panel.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 17, 2011 | HEWLETT-PACKARD Probook 4530S
What is the tiny orange light about in the left corner of my HP pavilion key pad ?
"You can double-tap a dot in the top left corner of the touch pad to disable it; a small orange light will appear to indicate that it's turned off."
Mar 01, 2011 | HP Pavilion N5495 Notebook
A red light comes on my hp touchpad and I loose all control, and can't get it back. How do i re-gain controll of my touch pad?
It shows that you have accidentally shut off the touch pad. In the upper left corner of the touch pad is a dimple/circular depression. Tap it twice, the light will go out and normal touch pad function will return.
Oct 10, 2010 | HP P2360AA Keyboard/Mouse
When I power up the screen flickers for a milisecond and returns to black. The fan runs. The hard drive gives a quick 2 second green followed by two pulses of amber for several minutes and then just quits
It sounds as if you have one of two possible problems, either the light tube in your screen is burnt out or windows is unable to load the video driver. When you see the HD green, it means the drive has started, the amber indicated it is working to load the operating system and then it stops - basically indicating it has found something it cannot load or is missing some files or is possibly busy. If your screen shows either the logo or the boot up screen (black with white letters usually), then the screen is working and it is a windows problem. Occasionally on updates or hardware changes it will take windows 5 minutes, up to a half hour at most to load - if you have a flashing cursor in the upper left corner of the screen, try just waiting to see if it will eventually load.
Oct 02, 2009 | HP Compaq 6715b Notebook
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Computer Frozen, Touch pad not working
there is a switch nearby that orange light or the light may be a switch. press on it then the color of light will change and ur problem will be solve....thats all
Dec 21, 2007 | HP Pavillion ZV6000 Notebook
HEWLETT-PACKARD Garden Dreams Pavilion dv5-2129wm Notebook Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Paul Bade
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
