Our magnavox TP 2526-c205 is not focused on the screen. It looks a bit blurry...Is there a button on the back that will help this?
Posted by missycrouche on
Anonymous
    Scholar:
    New Friend:
  • 100 Answers
Hi, ther is two buttones on the flay back part, you have to turn one of them until it will
be focused. the uther one is for adjusting brightness. the flay back is connected with a
wire to the top of the screen.good luck!
Posted on Feb 14, 2011
I bought the 10x25 camera binoculars and only one lens will focus using the center dial. Its almost like the other one needs to be focused at the eye piece itself. The pictures are not clear and are...
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
Aug 11, 2010 | Sharper Image Optics
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
I have a 10 year old phillips magnovox 55 inch tv
yes you can take off the cover but carefuly and in the back of your tv you will see the flyback and has 2 button one fro focus and other G2 then rotate the focus button till you will see no blurry
that is all if you dont know how bring some frend who can and tell him to do that
Dec 10, 2008 | Philips Magnavox 55P9271 55" Rear...
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
Magnavox rj8510 ak03 out of focus?
Thats your focus/ screen control block good luck on finding one.
Oct 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Big screen out of focus
ok you have to open the tv intill you see the 3 bulbs and the big mirror
the around each bulb is a wheel u have to turn that for the pic and focus
Jul 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
52" philips magnavox
theres focus controls inside the rear of the set on a small control panel with 6 dials 3 control the screens, and the other 3 control the focus for all three tubes.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
My picture isn't clear what to do
check ur t.v frm repairer or set brightnes as 85 & contrast as 90
Nov 20, 2007 | Televison & Video
Samsung Projection HDTV BLURRY!
Each projection set has focus controls in back, usually they don't move or go out of focus unless someone moves it, but in your case if you open the back you will see a focus block with 6 knobs 3 are for screen,I would highly recommend that you don't move this. Look for the focus and you will have to set each with the one color. Cover the other two and adjust.
Sep 07, 2007 | Toshiba 36A40 36" TV
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
