Question about Samsung SyncMaster 940MW 19" LCD Monitor
It will not come on when the power button is pushed
Posted by raybay7521 on
Bud Martin
  • 11,361 Answers
Look for caps with domed tops in the power supply/inverter board, see pictures here:
http://lcdalternatives.auctivacommerce.com/Search.aspx?k=SAMSUNG
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 09, 2011
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
1helpful
Printer does not print
Instructions
Error 5b00 is comming what is the solution
Solve error 5B00
Solution:
  • Press the power button to turn off the printer.
  • Hold the "Stop/Reset" button while pushing the power button.
  • Do not release the power button, release the "Stop/Reset" button and then push it twice in a row.
  • Release the buttons.
  • Wait 20 to 30 seconds until the LED shows 0.
  • Push the "Stop/Reset" button four times in a row.
  • Push the power button twice.
  • Turn off the printer by pushing the power button.
  • That's ok.
http://www.youtube.com/watch?v=RoiBaXVhS7g&feature=player_embedded
7helpful
2answers
Canon mp287 error 5B00?
hi me uttam jaiswal i have instaled MP287 inkjet but i have problem P07 get any solution
6helpful
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • 0helpful
    When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
    Please reset the Printer by following these steps:
    Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
    This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
    5helpful
    ERROR 5B00, no me deja imprimir
    1. Turn off the printer ( "Power" button).
    2. Hold the button "Resume" (red circle in the triangle) and push "Power" button.
    3. When printer become ready hold the button "Power" and release button "Resume".
    4. Push button "Resume" 2 times and then hold "Resume" and release "Power" button.
    5. When I hold button "Resume" I push and hold "Power" button and release "Resume".
    6. When I hold "Power" button, push button "Resume" 2 times and release both buttons.
    7. When printer become ready on the display write "CANON Idle".
    8. Push button "Resume" 4 times.
    9. Then push "Power" button 3 times to turn off printer.
    All done. The printer is ready to print.
    1helpful
    My printer reset button keeps flashing. i have switched it on and off and still does not work 1p3500
    Hi there
    Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset
    Ink level notification:
    1. Push “resume” for 5 seconds for canon For MPXXX you must enter to service
    Mode.
    2. Push Power switch then remove power cord.
    3. Insert plug power cord while pressing “power switch” at the same time.
    4. Push Start/reset by step 2 continue Wait display shown “0′
    5. Push + change display from “0′ to “1′
    6. Push colour button 2 times
    7. Push Power switch again, Printer will print 1 page
    8. Open cover
    9. Unplug power cord
    10. Take out ink cartridge #40 and #41
    11. Insert plug again
    12. Push power switch
    13. Open cover (scan cover)
    14. Insert ink cartridge #40 and #41 again
    Enter to service mode for canon MPXXX
    With the printer powered off but connected to a power source, press the Power
    Button while pressing and holding the Stop/ Reset button.
    When the Power is lit, press the Stop/Reset button two times while pressing and
    Holding the Power button.
    When releasing the Power button and the Stop / Reset button (regardless of
    Order), the printer will move into a service mode. (Waiting for menu selection)
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    1helpful
    2answers
    Error number 1700 canon s9000 printer
    knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
    Waste Ink Tank Reset
    1: Power off printer
    2: Hold Resume button then press and hold POWER, the beeper will sound once.
    3: Hold POWER and release RESUME
    4: Press RESUME twice, then release all buttons
    5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
    6: Press Power to set data
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    1. power off Printer
    2. Push and hold resume button and push power button
    3. Hold Power button and release Resume button
    4. Push Resume button twice ( 2x ), and now release resume button and power button
    5. Green light will blinking and stop.
    6. When green light on, push resume button 4 x
    7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
    Samsung SyncMaster 940MW 19" LCD Monitor Logo
    Top Samsung Computers & Internet Experts
    Jean Thiebaux
    Jax Planet
    Jax Planet
    aliasger yq
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
