Question about Texas Instruments TI-83 Plus Calculator
My calculator wont turn on. Even though i put new batteries in correctly. How can I turn it on? Nothing happens when I press the ON button.
Posted by stevesaint91 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Posted on Feb 09, 2011
My TI 83 plus is not working. when i press"on" nothing happens. I changed my AAA batteries, i even change the back maxwell battery, but nothing happened
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 27, 2010 | Texas Instruments TI-83 Plus Calculator
My ti 84 calculator doesn't work
Having received no response in over a month, I assume this is no longer a problem.
Jun 22, 2010 | Texas Instruments TI-84 Plus Calculator
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Put new batteries but it wont turn on... it was working before it ran out of batteries about 2 months ago..
Could be the screen has been dimmed so much that you can't tell that it's coming on. Press on and then 2nd button and the up arrow key. You may need to keep pressing 2nd and up arrow key. This is how you darken the screen. You can also lighten the screen which may be the problem you have by pressing 2nd and then the down arrow key.
If this doesn't work, take out the internal battery that is located in a tiny door with a screw right above the 4 AAA batteries. Leave this out for about 8 hours and put it back in. Put in the AAA batteries and the calculator will be reset and may work.
Jul 21, 2009 | Texas Instruments TI-83 Plus Calculator
New batteries, does not stay on and is unresponsive
I had the exactly same problem, and my TI 84 plus used to be extremely unresponsive and slow, as I have been fixing the latter problem by blowing really hard into the I/O plot, I did the same to fix the new problem. For many times not thing happened though. Then I insert a metal stick into it and gently hit the inside. In a short time, the calc was normal again!! Now my calc even turns on when it's been put off, with its cursor frozen. I simply use my little finger to dig/scratch the plot and see the lovely cursor beating again.
Mar 26, 2009 | Texas Instruments TI-84 Plus Silver...
Ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
Feb 14, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 92 will not turn on
Adjust the screen contrast
Press and hold [diamond] button (green near th [ON] button).
Press [+] to increase the contrast and [-] to decrease it.
Hope it helps.
Feb 01, 2009 | Texas Instruments TI-92 Plus Calculator
I have a Samsung digimax cyber530 that turned on with the lens coming out but will not do anything else (blank screem etc) I've put new batteries in and although when I press the power button the green...
I was borrowing the camera so the simple solution was quality long life batteries than the cheap versions (even though they were new) I had installed.
Mar 06, 2008 | Samsung Cameras
Batteries drains quickly
I had something similar, it kept saying "battery low" after putting in new batteries. Try the Clear method; Take out one battery, hold the Clear button, while holding it insert the battery again and press on, and release. Now press clear again, turn it off and turn it back on again. If that doesn't help... well it must be something else... sorry :S
May 30, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
157 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
