Question about Garden
My generator keeps cutting off after about 5 minutes of running...it is full of gas and oil...what's wrong?
Posted by kennetheh1 on
woobie dog
    President:
  • 1,273 Answers
Hello, W/D here.
Try running the generator with the fuel cap loosened. If it runs without shutting down, look for the pinhole vent in the fuel cap, and clean it. It sounds like you're fuel starved due to a vacuum being created in the tank due to the fuel being pulled out, and not being replaced by the air. Give it a try as this is a common issue.
Some generators do not have a venting cap (most do), and you may need to look for the vent, but there will be one.
Best regards, --W/D--
Posted on Feb 09, 2011
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
I have a GMC 2300w AVR generator which is pull start. it starts, runs for a min or two then cuts out..have clean fuel filter, air filter, spark plug, what else could it be...it still cuts out without...
Do you maybe have regular gas in it? Both Canadian and US regular gas now have ethanol in them and if the generator has sat for 2 weeks or longer then the gas is bad.Remove the gas tank and look inside. You will probably see an off-color blob floating around in the bottom. That is our wonderful environment friendly ethanol doing what it does best. Drain the tank and refill with premium. Restart the engine and do what you need to keep it running for about 5 minutes. If it has the plunger primer for cold start, use it every time the engine starts to die, 2-3 pumps each time. If not dribble a little gas into the breather to keep it going. After about 5 minutes it should start running on it's own. If not you will likely have to remove the carb and get the rubber seals replaced. Ethanol and rubber don't mix well.
After this keep premium gas in all your small engines. It doesn't separate. If you want to keep using regular gas then there are additives in the after market that will help keep it from separating. Hope this helps.
Sep 10, 2011 | GMC C2500 Cars & Trucks
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a proforce 2500 watt generator and it cuts out is this caused by low oil? if I change oil how much does it get?
Low oil doesn't usually make engines cut out. Clean the air filter, change the plug and wire. If this doesn't help then I think you're looking at a carb. problem. Probably just clogged jets & ports. It's very common on small engine carbs. It shouldn't take more than 2 quarts of oil. Probably not even one.
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Coleman Powermate 6250 stops after 5-8 minutes of running
the carby needs to be cleaned out properly the jets blown out with air.when you intendto stop useing for any length of time swich the fuel off and let itstop by running out of gas or drain the carby before storage ,as fuel evaporates and the additives dont they build upafter a while and start to block the jets make sure motor is level,oil cutoutcan be fooled if not level ,disconectwire if worried about that bing the problem
Jul 28, 2009 | Coleman Powermate Premium Plus 6250W...
New Onan 4000 watt gas RV generator cuts out
The generator engine is jetted for sea level. When you run at 24 hundred feet, it's flooding out. That's what you smell. The carb will need to be jetted for high altitude.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 30, 2009 | Electrical Supplies
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
john h
ray gallant
