Black horizontal lines ( page is held Portrait ) ,
where print is affected the print image fails to show behind Line effect but shows in between-
the drum surface has been damaged ( likely wear and tear) and can no longer maintain an even layer of electrons due to leakage/short
solution:
replace the toner cartridge which houses the drum.
Hi
That sounds like classic wear and tear issues. All those rollers and gears have very close tolerances and any variation out of the rang and the paper grabing and jamming starts. And that could be cause of the toner leaking. You must have a lot of miles on that ol girl and you got your moneys worth out of her. They dont make them like that anymore and I dont think you could find the parts even though that was back when they supplied parts. I asked an engineer once "couldn't they make that one gear out of metal like the rest of them?" He replied "well sure, but there wouldn't be any money in that..." You beat the system on that one. Time to start your research on a replacement I'm afraid.
Open rear cover and check gray plastic film not torn or broken. If film broken printer requires the fuser replaced. This is not a user replaceable item as its quite a tear down to reach the fuser.
Image defects may also be caused by toner cartridge. Check toner cartridge for background issues. To do this print the printer's demo page and open door when paper is half in the printer. Remove the paper jam and check unfused image for defects. If defects occurs then replace toner.
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Try cleaning the color or magenta cartridge with rubbing alcohol and look inside the printer to see if there's pooled ink anywhere that is smearing on the paper. Try replacing the print head or cartridge.
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
Did you try both cartridges? Sometimes a fried circuit on the color cartridge will cause a out of ink on the black even when the black is new. Double check that you are using the correct cartridge for the printer. and look at the copper/gold contacts in the printer where the cartridge goes. look for dried ink or tears. Clean with a Q-tip dipped in water. CAREFULLY. If it's torn.... enjoy your trip to walmart.
