Question about Braun IRT3020 Thermoscan Ear Thermometer
How do you change the battery? Mod. HM3 - Braun IRT3020 Thermoscan Ear Thermometer
Posted by lselby5 on
kzbihari
    New Friend:
  • 8 Answers
Replacing the batteries The thermometer is supplied with two 1.5 V type AA (LR 06). For best performance, we recommend Duracell ® alkaline batteries. Insert new batteries when the battery symbol appears on the display. Open the battery compartment. Remove the batteries and replace with new batteries, making sure the poles are in the right direction. Slide battery door back until it snaps in place. To protect the environment, dispose of empty batteries at appropriate collection sites according to national or local regulations.
Posted on Feb 19, 2011
How can I be sure if my PCM is bad???
I would try disconnecting battery again. Disconnect both cables and touch them together for a few seconds. This will reset all modules. Wierd that you had so many codes after just disconnecting battery. Sometimes very hard to tell if ecm is bad.
Dec 01, 2014 | 2006 Pontiac Torrent
Thermoscan hm3. When turned it just blinks not ready. What can I do
How old is the product? Return it under manufacture warranty. Alternatively, call the products customer support line and ask them for assistance.
Oct 19, 2014 | Televison & Video
I have a Braun Thermoscan model hm3 that I bought in 93. My thermometer changed from fahrenheit to celsius and I don't know how to switch it back.
I found this online and I used it to help me with the same issue. It also works for f to c. You will need something small to help you though.
Aug 24, 2011 | Braun Health & Beauty
How do I go about removing the batteries in my HM3 thermoscan?
Replacing the batteries - Using the tip of a ball-point pen, press the battery door lock to open the battery compartment - Using your finger, press the battery release - Remove the batteries and replace with new batteries, making sure the poles are in the right direction - Slide the battery door in until it snaps in place
May 17, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I have a Delonghi Dragon HM3 Oil Filled Radiator, its only a year and a few months old, I turned it off after using it for a few hours and now it won't turn back on. I have changed the fuse but still no...
does it have a reset button? Have you thrown a breaker to that plug in? Does that plug in work? Try plugging something else in and find out it could be as simple as a blown breaker. thats the only things I could think of
Mar 04, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
Eng mod fuse keeps blowing
Not sure what you mean by eng mod fuse. What's the year, make and model? What's the description of that fuse in the owner's manual?
Oct 02, 2017 | 2005 Dodge Neon
I have a Meyer mod # E-60H. Last year it seemed
You got the idea, because both the motor carbon
brushes and a weak battery is one of the major causes of your problem. So, have a check on these items.
Furthermore, also check the oil as well as the oil filter
if it needs to be replaced. When all the checks are done
and fixed, I'm sure that you will get the best result . Hope this will help you.
Oct 23, 2009 | Plumbing
.MOD extension is not recognized by my MacBook Pro for iDVD
How to convert .MOD file to mpg, avi, wmv and others?
If you got a JVC camcorder, or Panasonic camcorder or Canon MOD camcorder, you would have probably encountered such issue--- what to do with the MOD/TOD files----the God forsaken video format? And you want to convert the recorded .MOD file type to mpeg, avi, mkv, flv, mp4, wmv or whatever more common, so that you can put them on Youtube, Myspace, Google video and Hulu later on to share the camcorder video with your friends or more people? And there is another headache thing is that most major video editing suites seem to unwillingly accept the MOD/TOD format. Even windows video maker, I have to say it's too complicated to use
Someone successfully made it simply by changing the extension from .mod to mpg, but for most people, they just failed only to find there is no audio after the extension is changed, or the changed one doesn’t allow you to import these files into Windows movie maker, not to mention upload some video to Youtube.com or Facebook.
any alternativs? There is a very simple program that convert .mod NOT ONLY to mpg but many others like avi, mkv, flv, mp4, wmv, rm, rmvd, mov, dv, mg2 and swf. MOD converter is the one shoot all the trouble. This excellent mod conversion tool is not just a converter but also a video editing tool. From now on, with the MOD converter, you can enjoy your mod video on many media player, even on portable devices like blackberry, Gphone, PSP, Creative Zen,etc.
Things will be easier if you take a moment to finish reading the Step by Step on how to convert .mod to mpg, avi, wmv and others
Step by Step
How to convert .mod to mpg, avi, wmv and others?
Step1 Turn on your pc. Download and install MOD converter
Click here to download and install it by running iOrgsoftTODconverter.exe
Step 2: Turn on your camcorder and connect it to pc. Import the .MOD file onto PC.
Run MOD converter; select the .MOD file you want to convert by clicking the Add or File button to load MOD info. Click the profile button to define the output video format.
e3ccfd2.jpg Step 3: click the Edit button to set detailed info for the desired video.
A. Click the Trim button to set the length/range of the video that need to be converted.
You can choose a part of a MOD or the whole one to convert
B. Click the Effect button to tune the saturation, contrast, brightness values and make sure are the one you preferred, preview the change on the screen.
C. Click the Crop button to cut the unnecessary part or black part of the movie.
D. Select .AVI or .MPG and select the directory that you’d like your file stored to.
Step 4: Convert video
After all settings is done. You are ready to start conversion. This step will take you a while to carry out the conversion process, the time vary with different parameters you set.
MOD converter is a package tool, whcih actually includes mod to mpg mod to mp4 mod to avi mod to wmv mod to 3gp mod to mov mod to ipod mod to iphone mod to psp mod to iriver mod to creative zen mod to apple tv mod to blackberry mod to zune Wait a minute, if your exported camcorder video is in a .tod extention file style , it doesn't matter, we have TOD converter
Mar 26, 2009 | JVC Everio GZ-MG21 Camcorder
Braun IRT3020 Thermoscan Ear Thermometer Logo
2,589 people viewed this question
Top Braun Home Experts
john h
Tom Chichester
Are you a Braun Home Expert? Answer questions, earn points and help others
