Question about HP Photosmart C4180 All-In-One InkJet Printer
Trying to install an HP C4180 all-in-one printer. When installing the software, it hangs up on stage 3/4, Tried several times and re-boots, same problem. Have tried the print only driver but with same results Using Windows XP SP3 I could really use some help with this as its really holding me up! Thanks.
Posted by franc953 on
Muntejaya Ginting
  • 10,422 Answers
When I try to scan from printer to computer I get 'scan error'. See documentation. I am trying to scan to a mac - does that matter?
You need to use the grey cd to install the software onto your Mac if you have not already done so. If you don't have the Mac CD you can download the installation software and all drivers from HP here (select your operating system first).
If you have installed it aready, try uninstalling and then reinstalling using the HP website to obtain the updated drivers etc. rather than your CD.
Once you have uninstalled the software, disconnect your printer and then restart your computer. Do not re-connect your printer until you have reinstalled the software.
To verify that the software has installed properly, look for the HP Solution Centre on your desktop, double click on the icon and check that both "scan picture" and |"scan document" are showing.
Hope that helps!
HP Support manual for C4180
Nov 13, 2009 | HP Photosmart C4180 All-In-One InkJet...
Hp photosmart c4180 download
Un-install the printer and download drivers from HP. This link will take you to "choose your operating system" at HP. These will be up to date and may solve your error message. Good luck. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1141647&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20»
Jul 01, 2009 | HP PhotoSmart C4180 All-in-One Color...
INSTALLATION SOFTWARE REQUIRED
Click on the page below to download the driver. Follow instructions on page.
HP Photosmart C4180 All-in-One Printer
After download is complete unplug printer usb and install driver. The installer will tell you when to connect the printer to the computer.
Apr 29, 2009 | HP Photosmart C4180 All-In-One InkJet...
I have installed photosmart C4180 on my new Toshiba laptop (running Vista), When it gets to the stage where you plug in the cable there is nothing...i.e. it doesn't acknowledge its existence.(I then...
try plugging the usb connection to a different spot on the computer. it could be the usb ports dont work or could possibly not supply enough power to detect the printer.
Apr 27, 2009 | HP Photosmart C4180 All-In-One InkJet...
Printer Cartridges won't align C4180 printer
Printer keeps trying to perform an alignment after installing a new black ink cartridge fix:
1. Unplug USB
2. Turn printer off
3. Wait 10 seconds
4. Remove paper from paper tray so printer has no paper to print on
5. Turn printer on
6. Printer messages to insert paper in paper tray
7. Press and hold “Setup” and “ Cancel” buttons and press “OK”
8. Should be good until next black ink cartridge change.
Nov 28, 2008 | HP PhotoSmart C4180 All-in-One Color...
Installation problem
Had to format my puter hence having to reinstall everything using windows cd to install it only gets up second stage then it goes in reporting error bit before closing error quated =D:\set\hpzopt01.exe-IENU-fc:(windows)hpoinsII.dat Validation no-w-6029592
Trying to reinstall Photo Smart C4180 all-in-one
Please reply how to fix this my email is [email protected]
Stressed out heaps lol
Regards Sam
Jul 03, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C4180 won't print
hello
you can get the newest vista software for your laptop from
CLICK HERE
Apr 28, 2008 | HP Photosmart C4180 All-In-One InkJet...
Setup problem -HP Officejet 5610 All-in-One Inkjet Printer
ok..here's what you try now
remove all s/w for this printer
go here for most up to date(better than your cd)
install again
try it successfully
Mar 23, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C4180 All-In-One InkJet Printer Logo
efs_perpends
efs_perpends
k24674
