Question about Pride Mobility Products Pride Victory 9 PS 3Wheel Mobility Scooter Red
Power not going to solenide drive motor - Pride Mobility Products Pride Victory 9 PS 3Wheel Mobility Scooter Red
Posted by joanmasterdr on
Rob Hill
  • Pride Mobili... Master
  • 1,414 Answers
Hi, you need to check where the rear axle comes away from the main frame , the connections here are known to create problems,
Can you hear the brake unit clicking ?
remove the wheel, then remove the brake unit normally fixed by three phillip screws ,please take care not to damage the heads , now disconnect the brake unit but not the wiring, power on and move the throttle lever , does the motor turn ? then it's your brake unit that faulty or the wiring leading to it so check that out, in rare cases the controller has created a fault therefore not powering the brake so the motor cannot turn.
Motor still does not turn, then it either the output stage of the controller that's faulty or the motor itself which again is rare.
Please leave feedback if the advice helps.
Regards
GeWiz.
Posted on Feb 11, 2011
Shift solenid c where does it goes
buy a manual for your car and search for your answer
Nov 26, 2014 | Hyundai Motor 2003 Sonata
99 camry wont shift Code P0500 speed sensor
The problem is a gear internal failure the gear who drive the speed sensor is defect the is why you don't have speed sensor reading. There is a way you can verify that remove the speed sensor drive it with a drill check the dashboard you will see.
Oct 05, 2013 | Cars & Trucks
I think my starter or solenid is going. I can only start it about half the time on the first try. Otherwise it takes multiple times to turnover. Is the starter a pain to change on a 2000 Isuzu Rodeo?
i think you are on the right track it sounds like an solenide.But it could also be a starter pinion, the bit on the end of the starter/small gear.But its the starter motor that the problem ,sometimes you can get a recondition motor ,anyway not a big problem ,let me know if you need any more help.adrian,,,,,,,,
Aug 13, 2010 | 2000 Isuzu Rodeo
1999 Rodeo,, Isuzu, starter motor and solenoid
Follow positive wire to starter that has the solenid on it.
May 15, 2010 | 1999 Isuzu Rodeo
What does blinking lights with the four wheel drive indicate?
It indicates either 4 weel drive switch is bad or transfer case solenid is not engaging when 4 wheel drive is engaged.Hope I could help.
Jan 04, 2010 | 1999 Ford Explorer
Electric pto does not engage cub cadet 1040
if its an "GENERIC" problem,someone must have the solution..i would start with the motor, apply voltage direct to motor, making sure it worked,then work back through all the wiring,fuses,relays,solenids,sw,etc..etc.
Dec 13, 2009 | Garden
1994 grad prix wont start.
you could either have a bad key switch, that sometimes occurs, but most likly its the solenid on the starter motor if it isnt clicking, id have the starter/solenid checked out..
good luck and if you wouldnt mind please leave your feedback
thanks
May 21, 2009 | 1994 Pontiac Grand Prix
2004 nissian altima solenid problem
Your dad must have had his smarty pants on, the problem is likely the brake light switch, but I would get under there with a test light and a wiring diagram, make sure the switch has power before you replace it.
Mar 15, 2009 | 2004 Nissan Altima
My Ford f150 2002 transmission is slipping only when in drive. (4R70); what can be the problem?
could be the shift kit or speed sensor if changed already the solenoid sensor and shift solenid
Jul 25, 2008 | 2005 Ford F-150
Pride Mobility Products Pride Victory 9 PS 3Wheel Mobility Scooter  Red Logo
194 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
