Question about ScanSoft Nuance ® ® PDF Converter Professional 4 Full Version for PC
I cannot associate pdf files to open with nuance pdf professional. I have associated pdf files to open with nuance pdf professional. But when I double-click on the pdf file it gives an error message.
  • zoltansoos Oct 16, 2014
    What OS version are you using?
    New Friend:
    Problem Solver:
  • 7 Answers
Have a look at RE PDF processing control, here are guides on it for you solving PDF processing issue. It has free trial.
Hope it's helpful to you.
Posted on Aug 12, 2015
6ya staff
SOURCE:
Anonymous
SOURCE: PDF Converter Professional error
first of all check whether the file is not corupt or not and when it is not, then let me know the application logo on ur file and if it is adobe right click on the file then > properties > change. here u will look for pdf reader (adobe reader) then double click. let me know the feed back
Posted on Apr 07, 2007
Anonymous
SOURCE: PDF Converter4
i have a mpeg files but i want to convert it into a amv files where i can get a converter?
Posted on Feb 24, 2008
Jastababe
Terry Lynn Deschamps
  • 117 Answers
SOURCE: trouble opening pdf files with scansoft pdf convertor installed
Download and install Adobe Acrobat...it's free and will open all your pdf files
Here is the url, copy and paste it into your address bar..
http://www.adobe.com/products/acrobat/readstep2.html
~~Jasta~~
Posted on Apr 03, 2008
Anonymous
SOURCE: How do I use the erase feature in Nuance's PDF
In version 5, You go to Comments, then Draw Tools, then Rectangle (or other appropriate shape). Hold down to make box and change characteristics to white on white with opaque. Accidental boxes can be deleted by pointing to their side lines until the arrow appears and then select delete (to set white on white, just click Properties instead).
Posted on Aug 28, 2009
Anonymous
  • 5 Answers
SOURCE: need software serial number. Nuance scansoft pdf
A109X-K01-FJFD-BK5W-P4 this is the serial no.
Posted on Feb 13, 2010
One of our Sharpdesk users is unable to view her .pdf files that have been scanned in (as a .pdf) and sent to her desktop. We can view and open the file when we go in her c:sharpdesk desktop file. We just...
You can also right click on the file and left click on "open with" and then select choose program. In the list of programs choose Adobe reader and then at the bottom of the window put a check mark next to "always use the selected program to open this kind of file"
This should take care of the issue
Jan 22, 2010 | Sharp AR-M205 Copier
Cannot create or open pdf files..using nuance pdf converter4 professional
Try non-professional (free) downloading OpenOffice- you will find you can both create and open pdf files as if Mr. Adobe was sitting next to you...
It works with MS Windows XP if fact the entire suite is totally compatible with MS and other OSs
hope this helps
Apr 22, 2009 | Computers & Internet
Can't open .pdf file email attachments from Windows Mail (Vista)
Send yourself another known working PDF attachment and see if the same thing happens. If it does, post back. If not, then it most likely means there's either a naming issue with the problem PDF, or it is just corrupt enough to give you troubles when opening from email.
Mar 19, 2009 | Microsoft Computers & Internet
My ms word documents dont open when i doudle click
OK 5HEN,
If you can open the file from within Word (File, Open, ...) it sounds like you need to Set the Vista File Association:
1. Click the Start button.
2. Select Control Panel.
3. Select Programs.
4. Under Default Programs, select Make a file type always open in a specific program.
The Set Associations window will appear, allowing you to change what program a file type is associated with by selecting the file type and clicking the Change program button.
5. Since you are only looking to change a single file type (.DOC) right-click the ".doc" line - Microsoft Office Word - and select Properties. Under the General tab, click the Change button to select Microsoft Word program.
bettter-swiss
Dec 18, 2008 | Microsoft Office Professional 2007 Full...
Access to PDF files on email attachments
Try checking the file association. Open the Control Panel, Click on Folder Options, Select the File Types tab, Scroll down to locate the PDF extension, Select the PDF extension, Look below in the Details for PDF extension and select Change, locate and select Adobe Acrobat or Adobe Reader, then make sure there is a check mark in the "Always use the selected program to open this kind of file", Click on OK and then close.
Oct 15, 2008 | Adobe Acrobat 6.0 Professional for PC
PDF Converter4
You can try to manually locate the executable file, provided the install was not corrupt, by going to my computer then to the C: drive, then click program files. It may warn you about opening this folder but open it anyway.
Look for a folder with the name associated with the application name (i.e., nuance, ScanSoft, or PDF Converter.). Open that folder and look for the executable file. Once you find it right click on it and click send to, then click desktop(create shortcut).
Go to your desktop and try the shortcut. If it works, you can drag it anywhere you want it. If it doen't start the program go back to the folder and search for another .exe file and repeat the process.
Jan 06, 2008 | ScanSoft PDF Converter Professional...
I canit open files
Change the file associations in Windows. Right click a file you wish to open and then select the OPEN WITH option and then select CHOOSE PROGRAM. If the application you wish to use is NOT in the PROGRAMS list, use the BROWSE option to locate the one you want. Check the ALWAYS USE THE SELECTED PROGRAM TO OPEN THIS KIND OF FILE option and then click OK You can do this for any other file types that are wrongly associated. It may be worthwhile finding out what caused your file associations to get messed up in the first place. You may have a virus.
Sep 15, 2007 | Microsoft Windows XP Professional for PC
ScanSoft Nuance ® ® PDF Converter Professional 4 Full Version for PC  Logo
241 people viewed this question
Top ScanSoft Computers & Internet Experts
Al Rush
Barbat Nae
Barbat Nae
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
