Question about HP DeskJet F4280 All In One Printer InkJet
My deskjet F4280 has stopped printing with my macbook pro OS X 10.5. it was working fine until the last few days. I have tried reinstalling it, however, when i get to the "select the device model" page, deskjet F4280 doesn't show, even when i search for it. I have tried this with the computer connected ,via usb, to the printer, and with it not connected. still no luck. When I get to this point, a window by HP pops up and says, "if your device is not listed, it is not supported by this installer. then visit their website to download an installer." but the CD i'm using to install the printer is the one the printer came with and the one I originally used to install it.
Posted by ab_highrolla on
303 Electronics
  • HP Master
  • 368 Answers
That CD may not have the updated version. Check the following link and download the driver for your computer's correct operating system. It will take you throught the install process quickly:
HP Deskjet F4280 All in One Printer Software and Drivers
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Posted on Jun 17, 2017
2 Related Answers
Kenneth Brilliant
  • 39 Answers
SOURCE: HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Posted on Feb 17, 2010
Anonymous
  • 103 Answers
SOURCE: I run Windows Vista Home Premium os and have an hp
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Select replace current drivers
Do not select print a test page option.
Click on Finish.
Click on start then search type notepad.
Posted on Jul 12, 2010
I have a MacBook Pro computer and HP Deskjet F4480 printer ser # CN96GBM1M1 FPU # CB745.640001 My printer and scan have been working however the past few days I cannot print and the...
try to reinstal you printer.from the beginning.or try to install using CPUS from the mac.(http://localhost:631)on your safari or another web browser
I use windows 7 and my print doesnt work.i have hp deskjet f 4280.please answer me
The problem with using Windows 7 at this point is that they haven't even released the Gold Version which is the second to last release before they commit it to production. Usually the drivers are not finalized until the Gold Version, so it's almost a given that you will have problems with some or all of their drivers. Even HP couldn't help you with support for Windows 7 at this point. You might try uninstalling and reinstalling the driver.
1helpful
I just bought a HP Deskjet F4280 Printer, hooked it up to my HP laptop (Vista OS) and I'm trying to print a sheet of business cards. The right column has two business cards superimposed on top of one...
Looks like this has to do with the interaction between the Win 2007 (assuming Office) and the printer driver. Try reinstalling the driver for the printer. Even downloading another one from the HP site if necessary.
Can't scan on my HP Photosmart 4280
hi 1st of all remove ur old driver and then try to install this one from herehttp://www.userdrivers.com/Printer/HP-Deskjet-F4280-All-in-One-Printer/download/
Printer won't print..says doesn't recongnize usb connection
reinstall the software this should fix the communication problem. Make sure the usb cable is not attach until the software will ask to attach the cable.
Attempts to print on HP Deskjet F4280 shut down my programs
Sounds like the drivers are not installing properly. Are you installing through the CD or downloading the drivers from the HP website. Since a lot of the new drivers are no longer supporting XP you will need to download a scrubber utility and delete all of the pre installed drivers and attempt to reinstall through a manual installation of the drivers.
2answers
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
HP DeskJet F4280 All In One Printer InkJet Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
