Question about Whirlpool Duet GHW9150P Front Load Washer
"Control locked" light is on. Machine will not
Posted by jveloz9925 on
Czerney Dort
    Sergeant:
  • 170 Answers
Press and hold the button thats says control lock//that will unlock or lock the control panal...If it helped please vote need more help please ask good luck
Posted on Feb 09, 2011
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
Apr 05, 2013 | Washing Machines
Which brand and model do you have? Many manuals are available through the manufacturer (Whirlpoool, KitchenAid, LG); appliances sold by Sears often have manuals at Manage My Life: http://www.managemylife.com/mmh/owner_manuals .
The Control Lock is a child lock (to keep the program from being changed in use or starting a machine up with a problem load). To unlock it, you will need to press and hold one or two buttons (together) for 3+ seconds. The appropriate button(s) will have some text or icons indicating the feature; however, it is usually in a very small font. For some brands, press and hold the Pause/Cancel button. On LG models, it could be the Wrinkle Care button.
Please add a comment with your model and I'll see if I have your manual and give you the control lock toggle button(s) information.
I hope this helps.
Jun 23, 2011 | Washing Machines
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
The status light says "control
Thank you for using FixYa. The " control locked " is a safety feature to prevent the inadvertant use of the machine by a child. To unlock the controls press the "end of cycle "button for approximately 3 seconds until the "control locked " indicator light goes out. If you have young children in your home and want to lock the controls press the "end of cycle" button again for three seconds.
Please post if this solution has been helpfull
Thank you
Duncan
Mar 04, 2011 | Whirlpool Washing Machines
Re: Maytag Neptune Washer. Loaded 2 jackets (whites requiring bleach), added usual Gain detergent (granules), plus small amt. of bleach in dispenser, then started cycle. Then poured bleach into machine...
DO = Door Open
Door monitor switch in door lock mechanism is not able to communicate to the control board is open.
1.Make door is closed.2.Check for loose wire connections at switch and/ or machine control board.
3.Check for failed door monitor switch.
4.Check inputs and outputs at machine control board.
FL = Failed To Look
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
Dec 31, 2010 | Maytag Neptune Washer
My dishwasher is less than two years old - bought new at Lowe's. The "lock" light at the "Heat dry" button is on, nothing elese works. What's up with the machine?
Hello & Welcome to FixYa
The lock light that comes on indicates that the control is locked and you reset the control to solve this problem. To unlock/reset the control press and hold the NO HEAT DRY/AIR DRY/RINSE ONLY button for 15seconds. Please get back to me if you have any other questions.
Kevin
Dec 08, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 26, 2010 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
