Question about ASUS Eee 4G Notebook
Why does my Eee PC shut down once unplugged??
Posted by finallyfree1 on
Prateek Raghuvanshi
  • 253 Answers
Change your battery
Posted on Feb 09, 2011
Asus eee pc auto-restart not possible
it could be an OS problem try to re-install (your OS)
Asus eee pc shuts down when lid closed
Click Start/Control Panel and check the Power Options settings.
1helpful
My ASUS eee pc gets stuck on the windows xp loading screen. i have tried starting it in safe mode, command prompt, last known configuration, pressing F8 and every time it gets to the loading screen and...
Welcome to Fixya.
I see that you're having boot issues, here are some other things that you can try :
  • Ensure that the computer is turned off
  • Unplug/disconnect all USB connections
  • Unplug the ac adapter cable
  • Carefully remove the battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter without the battery
  • Turn on the computer
If the above procedure works,then you may reconnect all devices once the computer is up and running. Otherwise, I am recommending a full operating system re install.
I hope this helps, Thanks for using Fixya.
PLEASE MY EEE PC KEEP ASKING FOR A PASSWORD ON BOOT UP.
When you turn on the Eee PC you should see the Eee PC logo. Press F2 at that time to access the Bios. NOTE: recommend not to change anything else while in bios.
Once in the bios press the right arrow button to move to the tab labeled Security. NOTE: tabs located at the very top of the screen,
On the Security tab press the down arrow button to highlight the option to change the supervisor password and follow the prompts.
NOTE: to have no password leave password blank.
Once done press the right arrow button to exit and then press the down arrow button to select the option "Exit and Save Changes"
When the computer restarts it should no longer ask for password when turning it on.
8helpful
2answers
My ASUS EEE PC's mouse has completely frozen, even when the PC is shut down and restarted this problem is still present after logon. You can still kind of use the computer, but the mouse remains jammed. ...
Hi, this happened to me so I read the manual of keyboard shortcuts and it was Function and F3 - solved, what a relief - hope it works for you too - Kath
I bought ASUS Eee PC 1201PN. i used it for only a month because i discovered that there are ants inside and later didnt function well until it shut down.the repairman said it cant be repair and i can get...
PLease don't worry, the Serviced unit will throughly checked before delivery.
All the Components which are damaged will be REplaced with new once. So the Computer will be as good as new.
I tried to run a BIOs and it went to a black screen and would not do anything,so I tried to manually shut down and it wouldn't. I unplugged the cord and pulled the battery. Now it will not start up power...
you may have ruined the bios. Try removing the rechargeable battery AND the BIOS battery for 10 minutes, while the computer is unplugged. Then, install both, plug the cord and try again.
2helpful
2answers
How do i re format my eee pc?
1. Shut down eee PC*** 2. Power on eee PC 3. Repeatedly hit F9 4. ... 5. Profit
*** a simple restart doesn't seem to work for me. You need to shut down first.
Bought 3 Eee PC 900/XPs. Bought recommended Crucial 2GB SODIMMS to upgrade memory for all three machines. After upgrade and just after Windows XP loads the screen goes crazy. Crucial suggested...
pop battery out ...... re-start with cord power , then shut down completely. pop battery back in after 5 minutes .....and try that ......you may also want to check your power settings .
Eee pc linux properties not working
the harddrive is the problem. 4 GB's is a small drive, most programs need space for performance. think about an other larger harddrive.
ASUS Eee 4G Notebook Logo
Top ASUS Computers & Internet Experts
Roy May
Michael Thomas
Michael Thomas
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
