Question about Hotpoint Ovens
My hotpoint stove/oven timer buzzer will not shut off. been unable to keep it quiet for more than a few minutes or a few hours at a time. I want to be able to silence it permanently. How? BTW - not a digital model. it's the old fashoined spin dial one...
Posted by amyholl68 on
janettegillo
My timer buzzer is extremely quite. Can only just hear it when stood next to the oven. Can this be changed?
Posted on Apr 28, 2011
vstanner
    New Friend:
Amyholl68 Have you solved this problem? If so, please advise - mine is doing the same thing.
Thanks, VSTanner
Posted on Apr 24, 2011
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
The beeper on the stove timer came on for no reason at all, and I cannot get it to shut off for good. If I press timer, it will reset back to 1 hour and 59 minutes, but when it goes back to zero, the...
I would inspect the circuit board closely for a shorted component. If visually it appears normal it is likely the control board will have to be replaced. Eric
Aug 18, 2010 | Ovens
Hotpoint Openspace Timer problem
no, but can i ask your general opinion of this as thinking of buying one
Apr 07, 2010 | Ovens
Volume on timer really quiet hotpoint forno
Pressing the "-" button on the control panel will cycle through the 3 or 4 available beep tones / volumes. No need to press any other buttons during or before this process.
Shame Hotpoint didn't see fit to put this in the manual. We dicovered it by mistake!
Jul 29, 2009 | Hotpoint UY46 Style Line Stainless Steel...
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Dec 27, 2008 | Magic Chef 9512 Electric Single Oven
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
Ovens Logo
447 people viewed this question
Top Hotpoint Ovens Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
