Question about DISH Network 32 Ir 137180 Remote 5900 3100 4100
My bell remote is not working. i changed the batteries but no luck.
Posted by judy_ogorman on
Becki Barned
    Novelist:
    Champion:
  • DISH Network Expert
  • 286 Answers
Hello, this sounds like you have a problem with your DISH remote. If you are, here are some steps to get it working. The first set of steps is to get it working with the tv, the second for getting it working on your receiver.
TV:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
RECEIVER:
1. Go to System Info Screen
2. Press and release the SAT button on the remote one time
3. Press the black and red record button 3 times.
4. The number next to the remote address should change.
Becki Barned
DISH Network Customer Service
Posted on Feb 16, 2011
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
Just a thought if the bell is wireless your diagnosis may just be coincidental, but look to at swapping out the battery. can you press the bell, say 5 times one after the other ok? Batteries sometimes recharge slightly between presses, maybe just pressing it twice once after each other doesn't work.
Nov 19, 2014 | Cars & Trucks
My bell remote was drop on the floor now it won't go on guide are change Chanel's so I got another one it still won't work what's the problem
Power off, and unplug from the wall. leave off for a few minutes, put new batteries in remote control. Power unit back on, if problem continues, check remote if remote is working, if you have a smart phone, look and the RF sender on the remote through your camera on smart phone, you can see a change in light on the sender if the remote is working.
Nov 30, 2013 | Televison & Video
My Bell remote has been working fine since I had Bell and the remote isn't working like when I press any button on the remote the light on the remote goes red and red for a long long time I tried
1) clean the c.batteries with c. cleaner
2) retight the spring contacts batteries with long pliers for better contacts
3) open the remote control and clean the keypads for: dirty, corrosion, oxide, and bad contacts.
4) reset the code again.
5) try again.
6) if the problem persist, problem with the Syscon, you must go to repair shop for fix it.
God bless you
Oct 16, 2012 | Bell Televison & Video
Remote not working
open the remote control clean the keypads for dirty, oxide, corrosion and bad contacts with c.cleaner
2) reset the code
3) try again,
4) if the problem persist, some problem with the Syscon, you must go to the repair shop.
5) clean the contacts batteries, and retight the spring with long pliers for better contacts.
God bless you
My 3.2 IR 166173 BELL remote wont work on my bell reciver
Ensure that the TV is turned on. Turn the Bell receiver on manually (at the receiver). Remove the batteries from the remote. Press the "Power" button on the remote until no buttons on the remote light up (a half-dozen times). The satellite service (your Bell service) will likely have turned itself off in the process. Replace the batteries in the remote. The remote should now work as "normal".
Nov 26, 2010 | Televison & Video
How to program 9242 remote to work with my Bell
The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
Oct 13, 2009 | Bell Televison & Video
My bell tv remote isn't working for sat but works for tv etc, tried new batteries
It would be best to call Bell technical support before going out and buying a new remote control, they can help you re-address the remote properly. 1888SKYDISH
Jul 15, 2009 | DISH Network IR Remote Control
Universal remote code
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotehome.shtml
Code 720# for my 26" insignia tv on me bell remote 3.2 IR - 137181 and it worked for me. Click on link choose the type of remote you have.
Good luck
Lapete
Feb 09, 2008 | Televison & Video
DISH Network 32 Ir 137180 Remote 5900 3100 4100 Logo
7,391 people viewed this question
Top DISH Network Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
