Question about Gateway FPD2275W LCD Monitor
My Gateway FPD2275W LCD monitor went complely dead. I order cap kit and replace all 9 caps in the power supply. Of the 9 , 4 looked bad. Reassembled everything and now get the tones and the blue power light but no pic, not even the monitor menu.
Posted by lkcarte on
Rodger Hale
    New Friend:
  • 36 Answers
Can be that
other components have also failed each unit can have additional problems remaining
after replacing the caps.
[email protected]
also
interested in purchasing any units that have been deemed non repairable.
Posted on Feb 11, 2011
I have a fpd2275w momitor this morning blue light on and no display . what can i do or do i need a new
More likely to have bad caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/GATEWAY/Gateway%20FPD2275W/
Not an easy job.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 25, 2011 | Gateway FPD2275W LCD Monitor
Monitor turn on see the logo sign after went black can see anything once in a while you will see image after couples sec went black
Look for bad caps with domed tops first; http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 23, 2011 | Gateway FPD2275W LCD Monitor
The screen monitor went black complete
Look for bad caps as shown here: http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Be warned, this is not easy to take apart and must be real careful on the front panel ribbon cable.
Nov 27, 2010 | Gateway FPD2275W LCD Monitor
Moniter stays on only breifly bout 1 minute & then shuts off.
Look for bad caps in the power supply as shown here:
Be real careful when separating the front bezel or you will break the ribbon cable.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Sep 05, 2010 | Gateway FPD2275W LCD Monitor
I have a Gateway fpd2275W lcd monitor that will turn on for a few minutes then turn back off. I need to be sure what part is bad and where to get this part. thank you
Look for bad caps, they should be replaced as a set.
It is very difficult to open this monitor, watch out for the very small ribbon cable attached to front panel that you can easily ripped apart!
Aug 12, 2010 | Gateway FPD2275W LCD Monitor
I have the 22 in. FPD2275w black lcd monitor 2006 and everything is dead no nothing what can I do?
Bad caps, be REAL CAREFUL when take the bezel out, you can easily damage the small ribbon cable attached to the front bezel.
Jul 26, 2010 | Gateway FPD2275W LCD Monitor
I don't have power save on but my screen goes from bright to dim
Look for bad caps in the power supply/inverter board.
http://www.badcaps.net/forum/showthread.php?p=73310
90% of my LCD repair are due to bad caps, see example here of what is involved in repairing the monitors:
Make sure to use good caps, PANASONIC FM or FC series from DIGIKEY.
Post back what you find so it will help other people also.
Replacement bd: http://cgi.ebay.com/Power-inverter-board-monitor-FPD2275W--LP2207-E131175_W0QQitemZ370358203047QQcmdZViewItemQQimsxZ20100402?IMSfp=TL1004021510002r18789
Apr 05, 2010 | Gateway FPD2275W LCD Monitor
Power button does not light up and no picture.
Look for bad cap, should replace them as as set (red marking as shown in my pictures).
3: 680uF 25VDC
1: 1000uF 25VDC
3: 470uF 35VDC
Apr 24, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
