Question about Acer Aspire One Netbook 8.9" Notebook
Acer aspire one netbook says hybernating. How do I get it to turn back on ?
Posted by jsleton on
Rommel Alilin
    Guru:
  • 2,178 Answers
Press and hold the power button until it fully shuts down then press the power button again to turn on.
Posted on Feb 09, 2011
GET ACER ASPIRE ONE OUT OF HYBERNATION
Turn it off...hold the power button.
1helpful
I dont know how to restore my acer with linux back to factory settings
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
1helpful
I DONT KNOW HOW TO RESTORE MY ACER BACK TO FACTORY SETTINGS
My acer aspire one pav70 went into hibernating mode . how do i get it out of hibernation
It could have gone into hybernation for more than one reason.
Either it has been programmed to or the battery is low. Either way pressing the power button momentarily will get it out, if the power supply is plugged in or the battery is charged.
To remove the hybernation option, right hand mouse click on the battery icone on the desktop and change you power settings.
Hope that helps.
2helpful
2answers
How to reset myacer to manufact setting
  1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
  2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
  3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
  4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
  5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
  6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My acer aspire 5050 dosent start up after you shut it down and boot it up? Help me!!!
Unplug the power supply, remove the battery then press the power button 10x or more holding each press for about 10secs. Insert the battery, plug the power supply and turn it on. If it doesn't, repeat the steps. This should remove the static electricity stuck in the mainboard.
If it turns-on, set your laptop to hybernate when you close the lid so you don't need to shutdown it anymore. If it runs out of power while in hybernation, it should start again.
Just purchased acer aspire one 150-1786 netbook
You say you just purchased it, It must be under warranty, take it back. If its not under warranty it could be a number of things. removing and replacing the ram is the easiest thing to do. Does anything show up on the screen when you turn it on?
2helpful
3answers
My Acer Aspire one won't turn on.
I also have this problem with my Acer netbook.  I have only had it for 4 months and am in Turkey on an extended break at the moment.  I have taken the netbook to a dealer here and have been told the problem is the motherboard, verified by Acer themselves.  I am not happy with this as the netbook was not cheap and there appears to be a few Acer models with the same problem
Acer Aspire One Netbook 8.9" Notebook Logo
Steve Sweetleaf
Steve Sweetleaf
Michael Thomas
Michael Thomas
