Question about Motorola Mobility Rival A455 Cell Phone
My phone fell in a bucket of water mixed with bleach and dawn dishwashing liquid. I dried it off with a blow drier , took the battery out and put the phone and battery in raw rice overnight and day. It started to work except the sceen is white and i can't see anything.What should i do?
    Scholar:
    New Friend:
  • 38 Answers
You need to try Silica Gel Packets to dry out your phone. There was a good article on associatedcontent.com that explains how to dry a wet cell phone, iPods, or any electronics.
You need to place your cell phone in a zip lock bag with Silica Gel Packets. Silica Gel will remove all the moisture from the phone and its components, something air drying will not do!
Just Google "Silica Gel Packets" and you will find several companies selling these products. There is also a web site called: http://www.SilicaGelPackets.com that has them.
http://www.associatedcontent.com/article/1028188/how_to_dry_out_your_iphone.html?cat=15
Posted on Mar 04, 2011
  • 418 Answers
You need to leave the phone off for about 42-72hours for the water to dry off competly and you can do this by putting the phone in a place where heat is generated for to dry up the water inside the phone.
Posted on Feb 09, 2011
Phone fell in water
If it's at the point where the screen isn't working properly, it's dead. If you have some kind of extended warranty, it may cover it, but there's no real way to bring it back from being water damaged, unfortunately.
Jan 25, 2014 | Samsung Galaxy S GTI9000 Smartphone
Do I have to mix my joint compound or can I just use it stright out of the bucket?
On pre-mixed buckets, a lot of dry-wallers add just a little water and whip it up when tape and texturing. It flows of the blade better. But, if you're just repairing a few holes, dings and gouges, then no real need............unless it's really thickened up on you.
If you have a partial bucket and are not going to use it for a while, you may want to flick some water on the surface and lay Saran wrap on the surface, then cap the bucket.
Nov 10, 2013 | Adhesives, Coatings & Sealants
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I dropped my phone in the tolit and i took the battery and sd card. i dried it. all 3. then i used a blow drier. then put it in rice. will it work?
Yes it will work, since you have taken out a great quantity of water from it using the blow drier.
The steps to get it to work are:
  1. Remove the back cover,
  2. Then remove the sim card and the scan disc memory card,
  3. Then try to open it up by using a torx screw driver,
  4. then slide an object around the edges of the phone to remove the front cover,
  5. Then blow dry it for a while,
  6. Take note not to get the blower too close to the screen to avoid damages,
  7. Reassemble the phone back together and turn it on.
It will work perfectly fine. Since you have done most of the job, just carry out the rest and turn it on.
Take care and good luck
Dec 22, 2010 | Cell Phones
Put dish detergent in rinse agent dispenser by accident
Hello and welcome to Fixya.
Aside from physically removing the dispenser assembly ( which would be quite involved and include taking the door panel off ) you should be able to "nuetralize" the dish"soap" by adding as much "white vinegar" as possible into the same location as the soap...the jet dry reservoir.
In fact you may have to try this several times, but you could also try pouring straight water into the reservoir, but that will take some time since it is "soap" as opposed to detergent, hence needing a lot of water to de-lute it to much of a degree.
I'd go with the "white vinegar" and repeat that several times through a "rinse & hold" cycle. ( do not add any dishes or cutlery...run it empty )
You can also add a couple of tablespoons of "vegatable oil" directly into the bottom of the dishwasher and some of your regular "detergent" before starting the "rinse & hold" cycle. This will give the soap something to react with and the "detergent" will also help "neutralize" the soap,,,hopefully breaking it down as a result.
To answer the second part of your post...
The effect is going to be oversudsing in the rinse cycle since this is when the jet dry/rinse agent is dispensed in the cycle. So what I'm hoping to accomplish with these suggestion's is to minimize the oversudsing or prevent it all together until the reservoir is "purged" of soap.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...we all screw up, that's life ;o)
Good luck.
macmarkus :)
Jun 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
My samsung rant fell in some water is their any way to fix that or no
disassemble it as much as you can. leave it in a dry warm environment for about a week to dry out. put it back together in about a week. charge up the battery and power it up. cross your fingers it may work.
p.s. was it on when it fell in the water ?
Nov 13, 2009 | Samsung Rant Cell Phone
I have a Nokia N90 and it fell in a bucket of water,it submerge for about 6 secs after grabbing it out.I dried it off and imediately run a blow dryer on it,but not getting any display on screen,but it...
The best way to treat a phone after water submersion is to remove the battery immediately and allow it to dry near a radiator or other gentle heat source. Sometimes burying the handset in dry rice will speed up the drying out process.
Be prepared to take it in for repair if the above doesn't work.
If it's insured you should be covered for water damage.
Jul 07, 2009 | Nokia Cell Phones
Nokia 2630 unlock? please help...
take a hair drier and dry your handset first before you switch it on ...
remove the panels and dry ...
while drying dont put the battery ....
dry the battery separately with the hair drier dont impose too much heat on the battery that may leak the battery ....
after drying with the hair drier all the water vapours will be evaporated so by this after that you turn on the phone it will surely work ....
this is the best method to do ..
even the mobile technicians will also use this method only ...
so try to follow this & fix your phone by yourself ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 14, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Water damaged
take a hair drier & dry it fully by removing the panel ....
before drying remove the battery ...
dmt insert the battery & dry it ...
after all the water goes off it will work fine ....
if you visit the technician he will also do the same ....he will be just having a handy vaccum cleaner he will do with that ...
this will solve the problem ...
any doubts reply me
thank you
bye
dnt forget to rate my solution
Jun 30, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Motorola Mobility Rival A455  Cell Phone Logo
143 people viewed this question
Top Motorola Mobility Cell Phones Experts
Lawrence Oravetz
Vernon Taylor
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
