Question about Samsung B5722 Cell Phone
8 gb memory i can not open - Samsung B5722 Cell Phone
Posted by jsnlor09 on
Lastoni Wibowo
    President:
  • Samsung Master
  • 2,246 Answers
Format your memory with you pc
chose FAT file system at formating your memory
and insert to your phone again, then try it
i hope this helpful
thank you for using fixya
Posted on Feb 09, 2011
How to upgrade memory
on the back unscrew the screws there are two places memory could be held take both of one wil be hard drive and other memory
if you have 2 slots put 2x2gbs
if you have 1 slot put 4gb memory in
let me know for further guidance
Mar 30, 2013 | Gateway LT4008u Atom N2600 Netbook
For Acer Aspire 4720z what will be the Maximum support of memory? existing 1+1 GB.Can we expand it to 4 GB ??
The best way you can check the maximum memory this system can hold is to go to http://crucial.com and run the free memory scan tool.
This tool reads the memory in the machine, which slots they are in, how many open slots if any and what size the memory installed is now. It will then list any memory changes you can make in the system.
You should realize that unless you are using Vista or Windows 7, the maximum memory a system can utilize, is 2 GB.
Apr 14, 2010 | Acer Aspire 4720 Notebook
My 2 GB Kingston memory card is locked. how to open it?
You'll need to reformat the card in order to reset the flash memory.
This is fairly simple to do. Simply insert the card into your card slot and go into My Computer (or just Computer in your start menu, if you're using Windows Vista or 7).
Next, right click on the icon that represents your card (this will be easily recognizable by looking at the capacity of the drive, it should be around 1.6-1.8 GB) and select "Format...". Format your drive using the recommended settings (usually FAT32, Quick Format) and you should be able to access it.
Mar 22, 2010 | Kingston 2GB Secure Digital Memory Card
I am not able to open my memory stick of data traveler 40 gb
Dear,
You can do then please
!. Check the same Memory Stick on another PC (if possible then of same configuration as your PC)
2. Make sure your Pc has Updated antivirus.
If both are Ok then follow the steps
1.Backup the Memory Stick data on other PC.
2. Format the Memory Stick.
3. Paste the data back to the Memory Stick.
It will solve your problem.
Regards,
Rakesh Kumar
Apr 03, 2009 | Electronics - Others
I cannot view files in 4gb memmory card in this nokia3110c phone
NOKIA 3110
was not supporting 4 GB memory card.
maximum 2 GB memory card support on nokia 3110.
Apr 02, 2009 | Nokia 3110 Cellular Phone
Unlock 1 GB micro sd memory card of Kingston Made
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Jul 19, 2008 | Nokia N95 Cellular Phone
Samsung B5722 Cell Phone Logo
Top Samsung Cell Phones Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
