Question about Aastra Telecom 470 Corded Phone (TPAASTRAPT470)
I need help syncing my Aastra phone with my phone.com virtual pbx.
Anonymous
  • 418 Answers
You need to use your USB cord to do that you connect the USB cord to the two phones and transfer whatever you want to transfer
Posted on Feb 09, 2011
No dailing tone
HI Michael,
I have this site for you on how to set dialing tone on your IP Phone. Hope it helps.
https://www.google.com.ph/?gws_rd=cr&ei=8CNaU5KaFYKiyASIhoKACA#q=aastra+6753i+ip+phone+user+guide ( please choose the 1st link)
Apr 25, 2014 | Aastra 6753i IP Phone
Need to change the time on my avaya
It Sync with your avaya PBX.
http://downloads.avaya.com/css/P8/documents/100133133
-Karthik.
Sep 25, 2012 | Avaya 1403
Aastra 5631i passcode
you can read your instr. manual or download from www. retrevo.com
or call the supply from the phone or where did you buy the phone and get help via ONLINE via chat or phone.
God bless you
Jul 31, 2012 | Aastra Telecom Aastra 9316 CW Corded Phone
Where is the reset button on the aastra 9417cw
Looking at the user guide, doesn't mention a reset botton, maybe a power cycle (turn off and on) could help you, but for your reference, below is the link to see or download the user guide of your phone for more information:
http://www.aastratelecom.com/cps/rde/xbcr/SID-6B459A81-58EFF42C/en-ca/P0844339_Rev07_9417CW_UG_E_01_2011.pdf
Mar 05, 2011 | Aastra Telecom Aastra 9417 CW Corded Phone
How to set date and time on aastra 5370
I suggest you consult the user manual.
You can get it in PDF format here : http://www.aastra.com/cps/rde/aareddownload?file_id=7959-13627-_MAS_XML&dsproject=aastra&mtype=pdf
Please rate if this answer helped.
Thank you!
Feb 28, 2011 | Aastra Telecom Aastra 8314 Corded Phone
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
I need to view a user manual. your web site will not provide one
If you are talking about the Aastra 9116, it looks like you can download the user manual at http://www.florenceinc.com/en/new-phone-AASTRA-9116.php (acrobat file)
May 28, 2009 | Aastra Telecom 9116 Corded Phone
Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
May 04, 2009 | Aastra Telecom Aastra 9316 CW Corded Phone
PHONE IS ON FORWARD
I think forwarding is in your PBX rather than the phone.
On my system it is #1+ext to forward and #1 to cancel.
Sep 03, 2008 | Aastra Telecom Aastra 8009 Corded Phone
Aastra telecom 9316 cw
Yes:
http://www.aastratelecom.com/cps/rde/xchg/SID-3D8CCB73-12A0DEC9/03/hs.xsl/21564.htm#dl_instructions
Look at the bottom of page.
Mar 21, 2008 | Aastra Telecom Aastra 9316 CW Corded Phone
Aastra Telecom 470 Corded Phone (TPAASTRAPT470) Logo
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
