I Have an Indesit widxl126 will not go past the rinse cycle, just keeps rinsing. Have checked the pump filter but this is clear. If forced on to the spin cycle ( stopping then starting rinse only cycle) then it drains a nd spins ok. Any help much appriciated
5 Related Answers
Anonymous
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: washer go though all cycles but no spin
not a mechanical timer in this one..
Posted on Aug 30, 2007
Anonymous
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
Anonymous
  • 417 Answers
SOURCE: Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Posted on Feb 10, 2008
Anonymous
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
My indesit dishwasher is not drying when the cycle is finish
Possibly the drying /heater element is faulty. Check the machine isn't on a non drying cycle. Some machines will do the last rinse in hot water but leave the dishes to drip dry in the hot humid air after the rinse. If the dishes or water isn't hot during a rinse , I would say its the element.
Mar 21, 2017 | Indesit Dishwashers
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
Indesit WLA111 stuck on rinse cycle
There is a drain plug and filter under the drum. You access it from the front by taking the panel under the door off. Get ready for lots of water to come out when you take the drain plug off. Clean out the area of the filter and drain plug.
Feb 10, 2014 | Indesit WA 115 Front Load Washer
I put rinse aid in but it seems to not be working or at least it keeps showing that it is full and it doesnt go down? Also it seems that there is always detergent left in the slots after it gets done...
The rinse agent dispenser holds up to 8 ounces of rinse agent and only 2-3 small teardrop sized drops are added in the rinse cycle ,thats all it takes per cycle so a full dispenser could take 2-6 months to become empty depending on how often ya run the dishwasher.
As far as some detergent remaining,check the filter in the bottom of the tub for some blockage,if the water cant spray forcefully because its hard getting into the pump from filter blockage it cant wash that well
I hope this helps
Gene
Aug 03, 2011 | Kenmore Dishwashers
The machine doesn't rinse out his water in the machine. it washes still good, but the water stays in the machine. i cannot open the door due to water would spill out.
check that the water pump is working can you hear it running when the cycle comes to spin / rinse if not replace the motor if so then check all hoses for blocks. undo the water pump filter and see if there is anything jamming the pumps blades
good luck
get back to me if you need further advice
Dec 28, 2010 | Indesit W 123 Front Load Washer
Pressure up past 15 or 20 shortly after
The sand is clogged and needs a backwash or change.
May 25, 2010 | Hayward Pro Series 18" Above Ground Pool...
Washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Jan 23, 2010 | Indesit Washing Machines
The washer will not drain to rinse.
have you checked the pump it could be blocked?
Jul 01, 2009 | Indesit W 123 Front Load Washer
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
