If aluminum foil is stuck to the element, you might try turning oven
temperature to highest setting for a while to see if the heat will
cause the remaining foil to burn off the element. If it is a
self-cleaning oven, perhaps the extreme heat will incinerate the foil
during the cleaning operation. Another option might be to heat oven at
low heat, wear heat proof mitt, and try to gently scrape away aluminum
foil. If in doubt, contact your manufacturer and/or repair person.
It is always best to refer to owner's manual for operation, maintenance, and cleaning instructions.
You might try using a rasor blade. Just be sure to keep the blade flat against the glass surface and scrape gently.
Is there anything else i can help you with??
If you are satisfied with my solution then please don't forget to rate me as fixya..
