Question about RIM BlackBerry Bold 9700 Smartphone
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Posted on Feb 08, 2011
Apr 18, 2011 | RIM BlackBerry Bold 9700 Smartphone
Jan 28, 2011 | RIM BlackBerry Bold 9700 Smartphone
Aug 11, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Aug 11, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Jun 25, 2010 | RIM BlackBerry Bold 9700 Smartphone
Jun 17, 2010 | RIM BlackBerry Bold 9700 Smartphone
Jun 04, 2010 | RIM BlackBerry Bold 9700 Smartphone
Mar 10, 2010 | RIM BlackBerry Bold 9000 Smartphone
Mar 05, 2010 | RIM BlackBerry Bold 9700 Smartphone
Jan 09, 2015 | RIM BlackBerry Bold 9700 Smartphone
