Question about Nokia 6300 Cellular Phone
I had skype on my nokia 6300. but now m downloading it again but its not??? how can i get skype on my nokia
Anonymous
    New Friend:
  • 3 Answers
GO TO THE M.MOBANGO.COM
AND GO TO THE SEARCH MENU U GET SKYPE CHATING SOFWARE
Posted on Feb 08, 2011
  • Anonymous Feb 08, 2011
    UR TRICK IS REALY WORKING....THANKS BROTHER
My nokia 6300 s music player is not working
In Nokia 3110c and 6300 the problem of Music occurs again and again .There are many possible thing to cause this like using mmc of more than 512mb(1gb is acceptable),transfer of files via bluetooth etc.So, to fix this first download Oxygen Software :: Download and install it to your pc.secondly, open the oxycube interface >>> Hidden files>>> and delete all the dbmusic which is seen inside the folder.Restart the phone and try to start the music player.Good luck.
Dec 18, 2011 | Nokia 6300 Cellular Phone
I connect my nokia 6300 to the Ovi for update. At the end of dowloading, phone just shutdown before it end. Now i can't turn it on. How to solve the problem?
Dear did you know the disadvantage of Nokia PC suit and Ovi suit ?Don't try to do it again because during updating the USB connection frequently lose.Those who advise you to do this have less experience.In my opinion Pheonix is the best is the best solution if we don't want to contact mobile tech.So try this
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 6300 file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck.If you could not do please contact me.
Jul 25, 2011 | Nokia 6300 Cellular Phone
I cant open my music player....
What is the size of the memory card ? if it is more than 512mb this problem will occur again and again.Move all the data from phone to mmc.Restore it and try.if not solved follow the tricks
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Nokia flash file or 6300 file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 14, 2011 | Nokia 6300 Cellular Phone
I can't use opera mini in my nokia 6300. what should i do?
Hi there!
This is a problem that I have experienced with the Nokia 6300. What you need to do is to delete opera mini from your device and download it again at www.opera.com. Download opera mini and when you are asked to select memory card or phone memory,choose memory card. I experienced your problem when I installed it on the phone memory.
Hope this will help you Kind regards Martin
Feb 09, 2011 | Nokia 6300 Cellular Phone
Can i use skype in nokia 6300?
Yes but with out video calls. If you want videos try "fring" (a software ).
Think this is helpful !
Aug 12, 2010 | Nokia 6300 Cellular Phone
How do i download and store aplications for nokia 6300
you can download and store new applications directly for nokia 6300 from nokia link below:--
http://europe.nokia.com/support/product-support/nokia-6300/software
------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 24, 2010 | Nokia 6300 Cellular Phone
Downloading/installing adobe flash player on a nokia 6300
i want to download adobe flash player on my computer & then install it on my nokia 6300 mobile phone.
Jul 29, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 programs download
try to update the software used in it by contacting the nokia care
Nov 17, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
Resolution IT Dubai
Resolution IT Dubai
matt
matt
aliasger yq
