SONIQ QSL422XTV3 speakers have low humming sound - which is still noticable when running DVD in AV1 input source, even with TV volume down . Any troubleshooting sugessions?
Posted by nightwatch22 on
Anonymous
    Sergeant:
  • 142 Answers
Try placing it away from any unshielded power supply or motor as it may be due to electromagnetic interference. The cables could also be grounded. Try swapping the cables with a known working one to isolate the issue. Make sure that the terminals are free from any dirt which may cause poor contact between connections.
Try turning on the speaker as a stand alone. If it still hums, then you'd need to open up the speaker and fix it from there if you're qualified enough to troubleshoot the issue.
Hope this helps.
Posted on Feb 09, 2011
I have no sound in my tv
Yo need to check this things:
  1. Volume is not muted or on low level
  2. Try out other source TV/DVD/BLUE-RAY/ input for audio
  3. Check for NTSC/PAL/SECAM settings if analog input use
  4. Check your country standards for setting up right one
Tabele of standards Color subcarrier frequency and TV Standards TV Systems
Feb 09, 2015 | Televison & Video
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Strong humming sound coming from the over head speakers
are you running a stand alone dvd player or is it built in?check all plugs for sources coming ineg.dvd,vcr,xbox etc,if one is not in all the way,this will cause a hum.
Oct 20, 2008 | Sony DAV-C770 System
Model 60PL9200D/37 no sound
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
For HDMI,
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
Answer
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Apr 07, 2008 | Televison & Video
Webcam Speakers Echo and Double Feedback
"Noise", as used in this document, is a general term referring to any sound a speaker system makes that is not part of the original source material. There are many different types and sources of noise, each with its own solution. Below is an explanation of the common types of noise, what causes them, and how to minimize their occurrence.
Hum or Buzz
There are four common causes of humming and buzzing:
  1. Sound card If the humming or buzzing gets louder or softer with changes in the volume setting, this is an indication of noise coming from the sound card. In this case, check all of the connections to the sound card to make sure they are all completely plugged in and secure. Then, adjust the level setting of the sound mixer to obtain the best performance. Generally, you should leave your CD volume settings in the mixer at full and reduce the sound card's master output level down. For information on doing this, please refer to your sound card manufacturer's documentation.
  2. Unused input cables If you are not using all of the source inputs to your speaker system (such as using a 5.1 speaker system with a 4 channel sound card), the unused input cables will pick up noise. The solution is different for each speaker system, as described below:
    Z-540 / Z-560 (2 channel sound card): Depress the M3D button.
    Z-640 (4 channel sound card): Depress the Matrix button.
    Z-680 (2 or 4 channel sound card): Disconnect the unused input cables from the control pod
  3. High-power devices If you are using other high powered devices on the same electrical circuit, they may be causing hum or buzz. If so, discontinue their use while you are using your speaker system. Examples of such devices include microwave ovens, halogen lamps, power tools, etc. Also note that high-power devices with dimmer switches (such as halogen torchiere lamps) will cause an especially pronounced buzzing effect. To minimize hum or buzz, make sure that the dimmer switch on these products is either all the way on or off.
  4. Electric Polarity In many countries, the US being one, the electrical power grid is polarized. In these countries, the power plugs are designed so they can only be inserted into the wall socket in a single direction. For example, in the US one of the plug blades is larger than the other. To avoid humming and buzzing, both your computer and speaker system must be properly plugged into polarized outlets. If your wall outlets do not have polarized plugs, as in the case of many older homes, and you are using adapters to plug these power cords into the wall, it is possible that the polarity of either your computer or your speaker system is reversed. In many other countries, such as most of the European continent, wall sockets are not polarized at all - making it even more difficult to properly match the computer and speaker system. To solve the problem you will need to remove the power plug from the wall outlet, rotate the plug 180°, and re-insert it into the wall. Try this for your speaker system power cord, your computer power cord, or both. You should be able to find a combination that will eliminate the humming and buzzing.
Pops and Clicks
There are three main causes of pops and clicks:
  1. Sound Card Many pops and clicks are created by the sound card. There are two common causes: sound card quality and older or mismatched drivers. If the overall volume level of the pops and clicks goes up and down as you change the volume on the speaker system, the noise is being generated by your sound card. Lower quality sound cards don't include the necessary circuitry to cleanly remove noise from the sound output. Logitech's higher-powered systems, such as the Z-560 and Z-680, are also sensitive to the overall quality level of the sound card. If you are using an older or lower quality sound card, we suggest upgrading your sound card. The other primary cause is older or mismatched drivers. Make sure you are using the latest drivers for your sound card.
  2. Multi-tasking If you are running more than one program on your computer that accesses the sound system at the same time, small pops and clicks can be common. This is a function of your computer and/or sound card. A common example is using a program that generates occasional audio feedback (such as beeps or other sound effects) while listening to an MP3 track in the background. The solution is to turn off audio feedback in the first application so that the background MP3 track is uninterrupted.
  3. Interrupts in the Digital Bitstream On digital systems, such as the Z-680, it is normal to hear a very faint "tick" when you switch between inputs (by pressing the input button). You may also hear louder 'clicks' or 'pops' on a device such as a standalone DVD player or a sound card if it is plugged into one of the digital inputs. On some systems, this noise may occur when skipping tracks, switching audio streams (for example, from Dolby Digital to DTS), or navigating a DVD menu. The clicks and pops occur because the device is sending out an interrupted digital data stream. This behavior generally occurs with older software and older players, but is uncommon on most modern equipment. The Z-680 has been extensively tested with the latest sound cards, software DVD players, and standalone DVD and CD players. If you experience extensive popping and clicking, we suggest upgrading to the latest version of your software DVD player or, if using a stand alone device, trying a different speaker model. If you need more assistance with this issue, please contact Customer Support.
Stutter
A stuttering sound track is an indication of either insufficient or conflicting computer resources. Check to make sure that your computer has sufficient processor power and memory to handle the applications you are running, especially if you are using a software DVD player. Defragmenting your hard drive may also help. If you are sure you have sufficient resources, check to make sure that you don't have any conflicting IRQ or DMA channels.
We have also seen some software DVD player/sound card combinations that cannot properly output a Dolby Digital or DTS signal through the sound card's S/PDIF digital connector. (S/PDIF is a generic term for either coax or optical digital connections.) The result, when using a Z-680 hooked up to a S/PDIF connector, is a stuttering soundtrack. As mentioned, this stuttering is caused by the computer, not the Z-680 speakers. Switching the software DVD player's sound output to the 5.1 analog outputs will generally solve this problem.
Hiss
All high-powered amplification devices - everything from multimedia systems to home theater systems to movie theater sound systems -- generate some level of background noise, or hiss. In addition, low quality sound cards with poor signal-to-noise ratios can generate a significant amount of steady hiss that is reproduced on the speakers. Under normal conditions at a normal listening distance, the hiss coming from the sound system should not be noticeable. In a very quiet room, or if you place your ear very close to the speaker, you may hear a very low level hiss. This is normal, but should be completely masked by normal music and game sounds.
If you find that hiss is noticeable, it is likely that the speakers are too close to your listening position. If the speakers are too close, you will not obtain the best imaging of the sound and you risk damage to your hearing when the system is playing at full power levels. Try moving the speakers further away from your normal listening position. We recommend at least 18" for the moderately-powered systems (such as Z-340, Z-540, and Z-640) and at least 30" for higher-powered systems (such as the Z-560 and Z-680).
Also, note that the satellites in most Logitech speaker products are designed to be wall-mounted. Wall mounting the speakers provides two benefits: 1) it moves the of the satellites further away from your listening position, making any hiss less noticeable and 2) it moves all of the satellites further away from each other, providing better channel separation and surround sound spatialization.
Feb 16, 2008 | Logitech Webcam
LG 42PC5D Sound Lag
Turn the volume on the TV all the way down. Its becasuse you have the sound come from both sources. its kinda fun to play with.
Sep 24, 2007 | LG 42PC5D Television
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
