Hello i have an ibm thinkpad I1200 1161 and it doesn't allow me to charge my mum says its the charging pin where i put the charger in what do i do
Posted by alex_wright9 on
Mike Wheeler
    Champion:
  • 204 Answers
Chargers go bad too....Check the charger and use a good charge to see if yours charges.
Posted on Mar 30, 2011
IBM Thinkpad X60- Charging LED ( Amber) flashes continuosly- battery NOT charging
An incompatible charger could be doing this, as could a failed battery charging circuit in the notebook. It is also possible that the battery is no longer capable of accepting a charge. The universal charger must be able to provide the same voltage as the original charger and have an equal or higher rating for wattage or current.
Feb 08, 2013 | IBM ThinkPad X60 1706 Laptop Universal AC...
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Hello my question? can i operate my IBM r52 thinkpad with out a battery? because the battery will not charge and the thinkpad will not operate with the power cable?
Remove the battery and connect the laptop with the charger and it should operate normally. However, in the absence of battery you won't be able to get backup.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | IBM ThinkPad R52 Notebook
My ibm thinkpad when charging has a orange battery light. when i try to turn it on it won't go on . why is this?
battery is not charging. please try with diffrent charger still you face problem try to change battery.
May 03, 2010 | IBM ThinkPad R32 2658 Notebook
I have a new battery in my ibm a31 but it does not seem to be charging the battery bar is on 11 percent even though battey status says its charging
Check charging with a different charger. Or check the voltage output of the charger. It seems that the charger is out.
Nov 07, 2009 | IBM ThinkPad A31 Notebook
The battery in my ibm thinkpad t30 died,I replaced it with a new one. It will not charge.The charger seems to be fine. Any ideas why its not charging
A possible problem could be the charger port on the actual motherboard. I would recommend finding some one to take a look and replace the charger port.
Nov 01, 2009 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
IBM ThinkPad T41 (9 Cell Battery)
It can over charge it.
it happens alot with laptops.
Feb 04, 2009 | IBM ThinkPad T41 Notebook
Battery light yellow won't come
allow battery to complete charge (green lite)
Or change battery if chrge not completing.
(check your AC charger)
Jan 11, 2009 | IBM ThinkPad T30 2366 Notebook
Charger pin is plugged in but it doesnt charge neither does the charging lite turn on any idea? can be it a problem with BIOS ?
This is a common problem with the T20 & T30 series Thinkpads. The problem is with the power management chip on the motherboard. The pm chip regulates & controls the power input & usage, allows the machine to switch from AC to battery, and controls the charging. Unfortunately, you will have to replace the motherboard in order to fix it.
Jul 26, 2008 | IBM ThinkPad T30 2366 Notebook
Thinkpad A31 2652
Sometimes a BIOS upgrade will cure battery charging behavior... http://www-307.ibm.com/pc/support/site.wss/MIGR-44450.html
Feb 16, 2008 | IBM ThinkPad A31 Notebook
k24674
