Epson Perfection 2580 Photo Flatbed Scanner Logo
Posted on Feb 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you scan a slide on an epson 2580 scanner? It's scanning like a photograph not a slide.
ONE-Touch-Solution
Level 3:
  • Epson Master 1,679 Answers
  • Posted on Feb 08, 2011
ONE-Touch-Solution
Epson Master
Level 3:
Answers
1679
Questions
Helped
404694
Points
5442
You need the slide attachment, Read the Manual by clicking below.
Epson Manual
And the adapter should be included in the box which you purchased
Regards,
Ron
Scanning Slides from Epson Perfection V700PRO
Hi
Please reinstall Epson Scanner software it will solve your problem
Thanks
Can not scan negatives and slides
Download this manual and select "scanning films and transparencies" section and follow the instructions.
https://files.support.epson.com/pdf/prv7ph/prv7phug.pdf
1helpful
Epson perfection 2580 scanner will not start. Programs installed w/cd. Epson updates added. Just says" scanner can not start"
The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
I hope this helps.
(scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
1helpful
I have an epson 2580 it now produces somewhat
The only way you're going to know if it's the scanner or the driver for sure is to install it on say an XP machine and see what results you get. If it's still dark, it's the scanner, if not, it's the driver.
1helpful
File settings dialog box is too high on screen to read, doesn't drag down
Go to the display properties of your computer and change the resolution.
Goodluck.
sherlyn c.
1helpful
How to scan a slide
Hi Arlene,
Have a look here:
http://files.support.epson.com/pdf/per248/per248bb.pdf
This is the quick reference card that would have been supplied with the scanner, scroll through the information to page 5 which tells you how to scan film or slides.
If you want the full manual and information then have a look here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=41624&prodoid=46253280
I hope that helps.
Mike
Document Recognition
Hi!
Here is an OCR software which you can download for free.
Please click on the link to access free OCR (scan to text) software.
Thanks.
Epson 2580 scanner
The only thing I can think of is to turn you to be scanned image up side down in the scanner bed.. IE Rotate 180' As another work arround simply open up Paint etc,and rotate the image 180' and save, ya should be all good.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
